Old 03-09-2005, 08:42 AM
polytrash polytrash is offline
Default PT 6.4.1.Mix unexpectedly quits
Hi everyone,
when I try to create a new song on my internal harddrive, Pro Tools unexpectedly quits every time. This does not occur, when I save on an external firewire drive.
We have a G4 Dual Processor 800, OS 10.3.4., ProTools Version 6.4.1cs3, 80Gig internal harddrive, MIX3 on this setup.
I have already used MacJanitor to repair permissions.
What could be the problem?
Please help.
Thanx.
Jasmin Zamora
Polytrash Studios Berlin
Old 03-09-2005, 08:06 PM
Default Re: PT 6.4.1.Mix unexpectedly quits
Based on your info, it certainly seems to be disk related. Do you have DiskWarrior or TechTool Pro?
Old 03-09-2005, 09:43 PM
Hi Jonathan,
I ran Disk 10. Everything seems to be ok.
Jasmin
Old 03-10-2005, 12:47 PM
Try changing the drive's audio/video status in the workspace to record and see if that changes anything. Maybe it won't let you save there because that drive isn't considered a valid drive and instead of getting a prompt, you get a quit.
Old 03-10-2005, 06:17 PM
JC925602 JC925602 is offline
Mac Janitor does not repair permission, it only execute the con tasks. Disk Utility and AppleJack does. Delete the Digidesign Database folder on your hard drive.
Try Disk Warrior if you have it. Also you can create a new user and try again. If it work, it's probably bad preferences.
JC
Old 03-11-2005, 08:03 AM
Hi JC, hi Jonathan,
thanx for your tips. I guess I will get disk warrior and see what happens.
Jasmin
Pro Tools 9 wont start! Quits unexpectedly.... Quits during startup... dbC4G Pro Tools 9 11 03-09-2012 07:23 AM
PT8 LE Unexpectedly Quits metaltx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-24-2009 03:48 PM
PT 7.3.1 unexpectedly quits schulze Pro Tools TDM Systems (Mac) 0 04-19-2008 12:27 PM
Unexpectedly quits Stig Eliassen Pro Tools TDM Systems (Mac) 4 05-03-2005 01:34 PM
6.7 unexpectedly quits pbjnus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-07-2005 02:31 PM
