Oxygen 25 (2014) not recognised in PT LE 8.0.1 (Original MBOX)
I have just purchased the new Oxygen 25, which supposedly should be plug and play, class compliant etc., unfortunately this has not been the case. The keyboard turns on, and I get a 'found new hardware' screen, and when I launch Pro Tools, I can select the M audio keyboard in setup>peripherals, but I only get 'none' in receive from, and send to. I have seen a references to using preset 10 for directlink, but this keyboard only seems to go to 5. I looked into the available compatibility information as far as I could find, and was assured that with LE 8.0.1 cs2 I should be up and running. Well the keyboard is dead in the water, and will be going back shortly if I can't get this problem sorted out. I have windows xp sp3, but have never downloaded any windows updates, as I built a PC specifically for Pro tools, with no internet connection as this always causes the system to fail eventually. There is nothing else I can think of, and no drivers available to download for my system. I am starting to wonder if it is because of the original Mbox being retired. Please help. Marcel |
Re: Oxygen 25 (2014) not recognised in PT LE 8.0.1 (Original MBOX)
I don't know if it will work with Pro Tools LE 8.0.1, but you might try installing this from the M-audio website > Drivers > Keyboard series > Oxygen 25 (New):
DirectLink for Pro Tools |
Hi Bruce,
Thank you for the suggestion. I get an error when I try to run the m-powered installer which says I need 8.0.5 installed. It doesn't find the driver from the device manager either. No word from m-audio either... thanks |
Mbox 2 Pro Not Compatible with 2014 Mac Mini | kitorod | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-07-2014 04:07 PM |
MBOX (original) all LED's lit.Hardware not recognised. | hrtoad | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-30-2010 12:47 PM |
New Mbox 2 Pro Isn't Recognised in OSX | mintin42 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-05-2009 10:30 AM |
Mbox not recognised | paul harmer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-27-2004 01:16 AM |
