Buffersize Problems HELP!!
My Pro Tools system is working fine when in mix mode, I can easily mix with a fair amount of heavy plugins, but to my extreme horror, today when I tryed to record "4 track" test all I got was an "increase buffer size" and "decrease buffer size" answer; it happens on both 24 and 16 bit sessions, although in 16 bit mode I can record dead air as long as I don't feed it audio;When I doit, it stops saying that PT holded interrupts for too long (- 9093); What does it mean? It is extremely strange not to be able to record 4 tracks on a 1800XP Athlon with 512 Mb Ram and Asus A7m266 Motherboard.
Please Help!! I should be starting a new project on sunday!! L.G. [img]images/icons/confused.gif[/img] [img]images/icons/confused.gif[/img] |
Re: Buffersize Problems HELP!!
gerax:
The same thing happened to me! Try this. Save the session as a copy in 16 bit. This should solve the problem. When I bounced some tracks to disc at 24 bit, and brought them back into the session, I began to have the same errors. However, once I saved a copy of the same session at 16 bit, the problem went away. My friend told me not to record or bounce to disc using 24 bit and now I know why. I hope this helps. [img]images/icons/smile.gif[/img]
Ryan H. |
This may be of no help, but sometimes you get this error message when it seems like buffer size has nothing to do with the problem. A couple examples (for me anyways) are when you fast forward or rewind and then hit play, or sometimes using the '2 bars' option when midi recording.
How to get the low H/W buffersize of 32 | Dutchmountain | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 12-18-2009 10:34 AM |
Problems "incree h/w buffersize" in playback/recording | shaung | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-20-2009 02:15 AM |
ProTools LE 7+digi002 BUFFERSIZE PROBLEMS | LennieTheMan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-12-2006 01:01 AM |
Buffersize vs RAM | soebx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-01-2005 02:27 PM |
buffersize PT 6.4 ?? | hoijandee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-05-2004 01:01 AM |
