IAC bus drift
It is unlikely that this is a Pro Tools issue but thought I'd post in case anyone has experienced this issue.
I sync Pro Tools 12.8.1 to Cubase 9 within the same machine (Mac Pro late 2013 10.13.1) and sync is fine until a minute or so when I detect drift. After 2 minutes, I'm 20ms out...and so on. It's the same every time so there is some mismatch somewhere. I use Cubase for midi as it is superior to PT (sorry but it is) and track-lay everything to PT. I do this currently by internal bouncing as running in sync clearly doesn't work. Anyone had this? solutions? thanks |
Re: IAC bus drift
More info on this weird drift issue.
With frame rate and sample rates matching - Cubase drifts ahead when it's the master. For example - at 90.000 BPM, I recorded one bar of Cubase click into PT and when you zoom in on waveform at bar 2, it's 44 samples out!! (One plug in on session - click, unused) With Delay Compensation off in PT, it's 34 samples out. With NO plugin's at all it's 24 samples out. The results are IDENTICAL when Pro Tools is the master. I just don't get it. I honestly think the tempo's don't match. If so, which one is correct?!? Could it be to do with the interface I'm using for cubase? It's a Presonus on a USB bus. Obviously with Pro Tools, I'm using the AVID HD i/o's on loop sync. Maybe I simply need to accept that syncing DAWs any way without a word sync is going to be inaccurate. Last edited by Dr Fletch; 12-08-2017 at 10:41 AM. |
23.98 Audio Drift | Pebble Mill | Post - Surround - Video | 13 | 08-06-2016 11:57 AM |
LA Drift... | Pred80r | Pro Tools TDM Systems (Mac) | 0 | 03-30-2011 10:08 AM |
Audio Drift...why? | blastula | Pro Tools TDM Systems (Mac) | 5 | 01-19-2011 10:07 AM |
FCP Drift Issue | EarHole | Post - Surround - Video | 6 | 04-30-2009 06:45 PM |
PT 7.4 Video drift | soundfx | Post - Surround - Video | 9 | 11-29-2007 10:47 AM |
