Old 11-29-2017, 05:06 AM
rhcp_chupa rhcp_chupa is offline
Default Xpand!2 changes interface display
Hello. I'm using Pro Tools 12 on my Windows 10 x64.
My Xpand 2 plug in works fine, but every time I select it as a plug in to use on a new sessions, it changes the whole display or "appearance" of Pro Tools. Don't know how to explain it very well.
When I chose that plug in, all the buttons, tracks and everything look smaller, as if I've changed the screen resolution. And also, all the words on the toolbar are incomplete, and it looks like:
Fil Edi Vie Trac Cli Even AudioSui Optio... etc.
This just happens when I chose this particular plug in, and the changes remain even when I remove it from a track.
Here ́s the link to the screenshot: https://imgur.com/w5WhwLJ
As you can see both images compared, when it looks fine at the top, and below how it looks when I select Xpand!2
Any solution?
Old 11-30-2017, 07:52 AM
Jazztheory Jazztheory is offline
Default Re: Xpand!2 changes interface display
I have this same issue. It all started from loading a pre assembled template.
regardless of which one i chose (i.e Blues, Pop,) it would shrink just like you mentioned. the words on the top would be incomplete and sometimes not even be able to be clicked on. it also happens when plug ins are loading into the inserts. Xpand2 included.
Old 11-30-2017, 10:03 AM
Did you use Xpand2 before you opened a template for the first time?
Did it work fine or was always like hat?
Have you tried reinstalling PT12 ?
Please tell me if you´ve found a solution, or what should I do.
Old 11-10-2023, 06:53 PM
DigitalVortex DigitalVortex is offline
Hi!
I've just naturally "spiraled" down into this thread, after encountering the same problem today.
I wouldn't care, like I didn't for 25 years, UNLESS this didn't also imply that one of the plugins that I wanted to start using - Decapitator - gets visually distorted to the point of being unusable. And that's because you simply can't click on the buttons and turn the knobs since they are visually displaced due to this graphical phenomenon.
So, did any of you solve it in these past 6 years? Or do you have any ideas?
After distilling the cause of this issue, by importing track after track into a new session, it became clear that Xpand! 2 is the culprit behind this anomaly, because every imported track having it on causes this graphical change. And that "semi-permanently", meaning, that you can't just restart the session, you have to exit Pro Tools and reboot it.
I use Pro Tools 12.
Thanx in advance & regards!
/DV
Digi Tech Sup: Color Display & Aux Send Display bugs nob turner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-07-2010 02:43 PM
Display name in channel strip Display Roll ICON & C|24 1 08-08-2010 08:24 AM
DM5 MIDI interface to Pro Tools Xpand issue. 56BelAir MIDI 2 02-26-2009 03:07 PM
xpand loads distorted yellow interface czarthp Virtual Instruments 2 08-28-2008 11:04 AM
Plug-ins List display, view of the screen display andre67 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-23-2007 03:24 AM
