Old 11-24-2017, 03:21 PM
espron espron is offline
Default inconsistent behaviour solo/mute on hidden tracks
Hidden tracks loose their solo status as soon as they are hidden, but will maintain their mute status even when hidden.
Most of the time I’m on a Icon or S6, and in this case the solo status is maintained on hidden tracks, but when working in PT without these surfaces, solo and mute behaviour is inconsistent. This is unfortunate as I often hide my VCA’s when working on specific element but still need the VCA’s to retain their solo status.
This seems like a bug rather than a feature, has anybody else experienced this?
I’ve seen this behaviour on every PT 12 system I’ve worked on, but can’t remember if this was the case in earlier versions.
IMDB
Old 11-28-2017, 11:34 PM
Default Re: inconsistent behaviour solo/mute on hidden tracks
Is this not an issue for anybody else?
If this behaviour is by design, it is IMHO an inconsistent design, especially as the way this works changes when using PT with D-Control/Command or S6. I know that some other changes occur as well depending on the capabilities of the controller, you can for example include hidden tracks in layouts on the S6 but not on S3/Artist but this seems like a more basic issue to me
I think that this should be a pref, for example "hidden tracks cancel solo"
IMDB
Old 01-07-2018, 10:09 AM
Joseph_Egan Joseph_Egan is offline
This is annoying me greatly too.
Old 01-23-2023, 08:01 AM
Spoil the Child Spoil the Child is offline
Hi! Did you ever find a solution or workaround for this? I'm experiencing something similar though in a simpler scenario. If I make an audio track (with solo and mute buttons ON) inactive, hidden, or even hidden and inactive (that 2-in1 function) and then reactivate that track again, the mute button's on status is preserved, but the solo button's ON status is not (no longer yellow). It might just be me, but I don't recall this ever happening before?
I hope someone can help figure this out.
Thanks!
Old 01-23-2023, 08:50 AM
It's designed this way, and has operated this way as far back as I can recall - if there was a release that didn't work like this it was probably an oversight/bug. Hidden tracks in solo sounds like a nightmare to me.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 01-23-2023, 09:43 AM
Thanks for your reply, Rich! I'm not too sure myself. For the longest time, I was on PT 10 and only transitioned to Pro Tool Studio last year or so but never really got to do much work in PT till this year.
To be honest, the reason I asked about this is because the enabled solo button helps me remember that that previously hidden and/or made inactive track is part of a sub-group that I need on a sort of ready-and-standing-by mode, that it is still very much a to-be-considered option. Having a reactivated ("make active" again) track without a previously enabled solo button showing up as enabled again might make me forget and ignore the track completely in a session populated by lots of tracks. Apologies as I admit I have an odd way of handling sessions and have yet to figure out how to be more practical.
Maybe indeed this was the way it's always been and my memory is just failing me. Anyway, thanks again for your thoughts!
HTML code is On
PT 12.8 Hidden tracks loose their Solo status : bug bassmagnetic Post - Surround - Video 2 07-06-2017 01:36 AM
certain tracks won't mute when I solo others? c-post Tips & Tricks 2 05-14-2016 04:54 PM
Protools 10: mute and solo aren't working. (Solo safe is not on any of the tracks.) charlottewrinch macOS 2 04-14-2012 05:32 PM
Strange solo/mute behaviour on two tracks? Johnrg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-29-2010 11:45 PM
Can't mute/solo tracks....help!!! Steve2000 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 03-12-2003 09:12 AM
