Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 07-28-2017, 03:21 PM
przemak przemak is offline
Default Re: HDX card and 96io on windows?
Well, I'll try HD native :)
I work in 44,1 so I can expect tracking drums with 32 samples buffer, right?
Old 07-28-2017, 06:02 PM
I doubt you will need to. HDN at a 128 buffer is about the same latency as a firewire interface(003) is at 64. I track at the 64 buffer setting with no mention of latency(unless something is messed up)
Old 07-29-2017, 03:27 PM
Well, OK, after almost 20 years with hardware PT having no latency is obvious. So the question is not if I need it but if I can get it
Old 08-28-2017, 08:33 AM
Well, got hd native, so far so good, thanks for the advice!
Old 08-28-2017, 09:04 AM
Fingers crossed that you dig it as much as I do I just spent another day on the friend's HDX rig helping him with some templates. He had 2 Waves reverbs that were causing over 2000 samples of latency. The same reverbs on my rig report 33 samples. Things that make you go "Hmmmmm"
  #16
Old 08-28-2017, 10:52 AM
Raoul23 Raoul23 is offline
That sample thing is strange because waves don't do AAX DSP so wouldn't you both be using AAX Native ???
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
  #17
Old 08-29-2017, 08:38 PM
You are correct. But for whatever reason I can't figure, native plugins on an HDX rig seem to exhibit more latency than on an HD/Native system.
  #18
Old 08-30-2017, 12:27 AM
Now that's very strange
Raoul Crane
  #19
Old 08-30-2017, 01:01 AM
Southsidemusic's Avatar
When we mix Native and DSP plugins on our HDX2 rig we get more samples aswell but by putting the Native plugins first we got a HUUUUGE difference so maybe try that. Everytime we have a session with both AAX-Native and AAX-DSP we do this and vσila .... Computer technology is a weird animal
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
  #20
Old 01-04-2018, 02:53 PM
Dan IceWood Dan IceWood is offline
This is because when you use an HDX card, the mix engine runs on the CARD.
This means that when you pipe audio from there to your CPU for native AAX processing it then has to be returned to the cards mixer for Playback through the DA. This is what incurs these long delays. Just stick with DSP plugs when recording. The SONNOX reverb is only 7 samples.
AVB-E card for Windows maunaloa VENUE Live Sound Systems 9 04-11-2015 01:18 AM
Big Ben & 96i/96io Siegfried Meier Pro Tools TDM Systems (Mac) 5 07-10-2013 03:02 AM
I want to use my 96io as my regular windows 7 sound device. Neily Windows 3 12-17-2011 02:27 PM
Should I add a FW 800 Card to my Windows PC? hammerransom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-30-2010 04:58 AM
Using 96io on Windows from Mac? Simple help? buckaroo Pro Tools TDM Systems (Win) 3 04-16-2010 11:05 AM
