#21
Re: MIDI Production PT 12 Impossible
I may get the odd 6101 error but maybe once every couple of months or so of daily use. Then again most of my new MIDI work is happening in Digital Performer 9.02 and less and less in PT. I have reasons for the switch that aren't germane here and if you want to know why PM or email me and we'll talk. |
#22
At some point in ProTools 11 or 12, Avid added a feature where you see a shadow of the MIDI notes when you move a MIDI clip around. This feature is completely unnecessary, and I think it is where the more recent MIDI problems started.
As to the more stringent requirements of ProTools 12, my CPU usage is at 14%. An interesting note is that offline-bounce works very well. A 2 minute piece of music with virtual instruments and plugins mixes down in about 10 seconds. I would think that shows plenty of CPU power available. The problems seem to be real-time coordination, resulting in the AAE - 6101 errors. John Clavin
John Clavin - AKA: Old Horseface |
#23
i'm sorry, it will probably not help you big time :
i have no problems with pt12hd on a mac 4,1 (early 2009) pimped to 5,1 with 6-core 3,46 GHz xeon and 32Gb 1333MHz Ram, Radeon HD5770 GPU. i use a HDX card. my OS is yosemite (10.10.5). i have the note 1 midi bug as well, but no nasty other errors. maybe the problem lies with your Audio Interface, Graphics Card, broken RAM. just want to let you know that having a stable PT system with a Mac 4,1 is possible. Last edited by edwinstar; 04-24-2017 at 12:49 AM. |
#24
Agreed. More ram should make for a smoother experience all round. I have 64GB, but MIDI is still what it is in PT...unacceptably unprofessional. Avid is utterly incompetent, but I'm tired of ranting on the DUC. Industry standard indeed.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
#25
That offline bounce figure - do you have any of your vi's rendered out before the bounce or not? How many tracks and what kind of plugins? And are they all Avid plugs or third party? |
#26
And it´s a 2012 MBP. But MIDI makes problems in PT. - Copy/Paste/Duplicate/Loop clips -> sometimes the first note in the clip disappears - the first note will not play sometimes - clips in sequence that are sized to the grid overlap each other. so this is neither related to the OS nor to the computer performance, it´s PT-MIDI Sierra 8GB RAM SSD drives no performance problems
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
#27
#28
as you I have been more or less unable to compose in Protools with VIs since version 11. V11 had a new Audio Engine, alas it was not better than the old one. As soon as the session gets a little bigger than one VI I have to up the PB Engine Cache so much that I cannot play with a feel via Midi. In the midst of Version 11 I was forced to switch to Logic Pro 10 for all my compositions as I would loose my temper before even getting to the nitty gritty of my composition. I was dumbfounded over the fact how easy Logic was Workflow wise and over the fact that no matter how many VIs I threw at it, it would never choke. If you really need Protools and rely on VIs may I suggest you use NI Maschine. Launch it as a standalone and do you Composition there. Then close the stand alone and launch Protools and load up Maschine as a Plug in. Hit play and enjoy. NI Maschine has great midi edit capabilities (Better and more reliable) than those of Protools (IMO). And aside from AAX Plugs it will load AUs and VST, VST3s. Another option is to use Logic Pro to Compose and bounce the tracks (Very easy and fast in Logic) and import them in to Protools. As to a remedy for what you are experiencing, I am sorry to say that in my quest of finding one, I haven't found anything but utter grief. I feel left alone with a $20000 AVID Investment that I have sold for $4k but now produce happily on a 2016 MBP with Logic Pro X selling for $199 !
2016 MacBook Pro Retina | 16GB RAM | 1TB SSD | OS X Latest - PTHD 12 Latest | 4K LG Thunderbolt Display | Logic Pro 10 |
#29
Logic is an excellent compositional tool, and PT elegantly covers the rest of the process. I no longer spend my time pulling my hair out. tg
Mac Studio (2022) M1 MAX / 64GB / 2TB HD / macOS Ventura 13.6.5 / RME BabyFace Pro FS / SSL UF8 + UF1 + UC1 / Roland SYSTEM 8 / Kontrol S61 mk3 / Pro Tools Studio 2024.3 / Nuendo 13 / Reaper 7 / Komplete 14 / Omnisphere / Keyscape / Trilian / V Collection X |
#30
Virtually impossible - MIDI Mysteries solved for US$10 | unkJE | Virtual Instruments | 0 | 08-05-2014 02:53 PM |
Is it impossible to load an old MIDI file into PT and get it | Elton Hyland | MIDI | 5 | 05-23-2007 05:54 PM |
HD as a serious midi music production platform ? | Stjernholm | Pro Tools TDM Systems (Mac) | 10 | 10-18-2006 02:46 PM |
Controllerless MIDI production? ANY POSSIBILITIES? | eascya | Virtual Instruments | 4 | 09-17-2006 11:20 AM |
multiple or impossible midi notes | Re_Org | MIDI | 0 | 08-02-2004 05:31 AM |
