Old 02-14-2019, 10:25 AM
ihate100bees ihate100bees is offline
Default Need to transfer from Mac drive to PC
I have several Pro Tools projects and files that are on a Macintosh formatted hard drive. Which software can I purchase to be able to transfer the Pro Tools complete projects and wav files over to my PC? I am hoping there will be no difference in the Pro Tools projects between MacIntosh and PC as well. I currently use Pro Tools 2018.7 for my PC, but I have no idea which version of Pro Tools is on the mac Drive. Thanks
Old 02-14-2019, 10:39 AM
jeam25's Avatar
jeam25 jeam25 is offline
Default Re: Need to transfer from Mac drive to PC
Hi you can use paragon HFS+ or see wich one fits you . They have a few options of it .
- Jesus Alvarado -
Keep the volume UP !
Old 02-14-2019, 10:48 AM
jryser's Avatar
jryser jryser is offline
Paragon is great!!
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM,
OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED!
B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED!
I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series!
Old 02-14-2019, 11:43 AM
Thanks I have heard of that software before. Apparently the transfer was done using Pro Tools versions 7 and 10. I'm hoping that my Pro Tools 2018 .7 will open the projects just fine and convert them into my PC.
Old 02-14-2019, 02:57 PM
thanks! Have you tried others? I also see MacDrive Standard 50 bucks compared to paragon 20. I did notice that you can read a cd or dvd from a Mac with MacDrive. could you do the same with Paragon? is one any better, faster or easier?
thanks1
Old 02-14-2019, 03:30 PM
Which do you like better... MacDrive Standard or Paragon HFS+ ?
thanks
Old 02-14-2019, 03:49 PM
I've had both and while I prefer MacDrive, it was not available for Windows 10 when I last needed it. That forced me to get Paragon, which is a lot less money, but slightly less convenient(sessions work best if I copy/move them OFF the mac hard drive and onto my recording drive). You should have no trouble opening the older session but for 2 caveats:
#1-if they were save in SD II file format, you need to open on a Mac running PT10(or 11, not sure) and older so you can convert to wave format.
#2-some plugins are going to need to be replaced with newer AAX versions(not everything made the jump, unchanged).
Old 02-14-2019, 03:55 PM
thanks for your info. Much appreciated! I think I will download the trial of MacDrive and go from there.
Old 02-14-2019, 05:34 PM
Media Man Media Man is offline
Mac Drive here as well. Been using them for many years.
Media Man
Old 02-14-2019, 10:48 PM
JCBigler's Avatar
JCBigler JCBigler is offline
Use a drive formated as ExFAT. Readable and writable by both Windows and Mac OS.
Justice C. Bigler
www.justicebigler.com
Home/mobile: Lenovo P50: quad-core i7-6820hq, 64GB, 2TB SSD, Win 10 Pro / Focusrite Red 8Pre / Protools HD Native 2018.10 Ultimate
Transfer PT-11 to new laptop but with no CD drive MEWCO Pro Tools 11 2 05-01-2017 05:22 PM
A llittle confused (audio drive and transfer drive).... JoyMODE101 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-06-2009 03:22 PM
Help w/ Transfer only problem on EXT Drive jjhuntfox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-12-2007 10:57 PM
Windows to Mac FW drive transfer lynxxx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-11-2004 02:20 PM
Firewire drive transfer lcouri 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-04-2001 08:00 PM
