Go Back   Avid Pro Audio Community > Other Products > Pro Tools Express on Windows
Old 07-21-2012, 03:02 PM
krisd krisd is offline
Default Beginner Advice on System Upgrade & General
THANK YOU AHEAD OF TIME!
Hello- New to Pro Tools (I am going to familiarize myself with it- but would rather use a different system), but I have experience running other programs. I just got an MBox Mini and have PT Express installed. My computer specs are at the bottom. I will spend the next few days tweaking my laptop, but as of now things are not working properly.
I should say that, I'm not looking for this to be my main setup, though I do need a working portable setup (mainly for getting ideas down, etc.)
A few problems I've had out of the box are:
1). Computer won't start while MBox is connected. I have to plug it in at startup.
2). A channel will start distorting the signal after a minute or so. Any ideas?
3). Looking for any advice on upgrades to my laptop. I'm sure I will get more RAM, but other than that....any advice?
4). I keep hearing about the "notebook compatibility chart. Forgive me for not finding it, but any help on it's location will be appreciated.
5). Any recommendations on a good plug in for dirty organ sounds or a gritty reverb plugin are also appreciated.
my computer:
toshiba
model: satellite a665
processor: intel (R) core (TM) i3 CPU M 350 @ 2.27 GHz 2.27 GHz
installed memory (RAM): 4.00 GB (3.80 GB usable)
system type: Windows 7 64-bit OS
up to date: standard driver: ST9500420AS version 6.1.7600.16385
up to date: graphics intel (R) HD Graphics version 8.15.10.2119
up to date: Intel 5 Series 4 port SATA AHCI controller version 9.5.7.1002
up to date: Processors 4 x intel core i3 cpu m350 @ 2.27 GHz
up to date: Chipset...Intel 5 Series/3400 Series Chipset Family PCI Express Root Port 1- 3B42,44,46,48,4A
Intel 5 Series/3400 Series Chipset Family SMBus Controller- 3B30
Old 08-18-2012, 05:38 PM
kyluigi kyluigi is offline
Default Re: Beginner Advice on System Upgrade & General
Im running pro tools 8.05 le and a few weeks ago had the problem you were having with audio distorting! I think the fix was to trash the preferences. Which you can find out how to do on this forum, another user made a preference trasher utility called trasher. Try google though if all else fails!
Regarding Pro Tools not starting unless the mbox is connected, I know on with PT8 and before you had to connect digi/avid hardware to use pt. Then with pt 9 and 10, came and you use ilok so you don't have to connect hardware. Im not sure how pt express works but it may be similar to PT 8 le in that you have to connect hardware. Not sure though.
Also not sure if you get the stock organ (DB-33) plug in with PT Express but if you do, that will give you a great organ sound.
Upgrade from Mix System - Need advice? starburst Pro Tools TDM Systems (Mac) 19 12-27-2012 09:49 AM
Preamps for 003, and general beginner advice? saucysauce 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 17 09-16-2010 08:05 PM
Upgrade Options: General Advice needed please Rich G 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-24-2010 05:19 AM
Advice on Upgrade Comp and Pre for 001 system? peneslapepe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-16-2003 07:01 PM
Advice on system upgrade dougl Pro Tools TDM Systems (Mac) 0 01-03-2000 01:16 PM
