Old 05-07-2012, 03:21 PM
Great Divide Studios Great Divide Studios is offline
Default Icon: remove send using "Set to Default"
Please add this to Icon D-Control. Removing a send should work the same as removing an insert: pressing "Set to Default" and then pressing the appropriate insert select button on the channel strip.
Go vote here: http://protools.ideascale.com/a/dtd/...ult/94872-3779
Thanks,
Jamie
Jamie Rosenberg
Aspen, Colorado
www.greatdividestudios.com
Old 05-07-2012, 06:36 PM
Brent_Sydney Brent_Sydney is offline
Default Re: Icon: remove send using "Set to Default"
Voted and +1 here.
But I still think plugin maps not staying put is a bigger bug than things like this.
Is there is a way to "remove" specific Plug in parameters to see less in MC Control? AMIEL Artist Series 4 11-11-2013 03:04 PM
Can you have "center" as default view with multi mono plug in? dgoodi22 macOS 4 02-08-2013 12:41 PM
What would be the "Best" or "General" Quantize default settings? Norm Mix MIDI 0 07-10-2009 12:38 PM
If I "Remove Unused Regions" after "Consolidate", track won't play? el biciclista Pro Tools TDM Systems (Mac) 10 04-02-2003 10:17 AM
"Bouncing" . . . . Can I CHANGE The "Default Setting"?? The Zone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-17-2002 02:59 PM
