Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 06-06-2011, 09:23 AM
TDub TDub is offline
Default Roland TD 4ks ...?
Hey everyone,
Just looking at purchasing the above rig. Want to use it to play with a more natural feel than programming, but have it trigger from Strike and/or EZ Drummer. Will this kit work well? Any thoughts? Simple to do?
appreciate it
TDub
Digi002 R with Command 8 - PTLE 8.03
Intel Quad Q9550
Asus P5Q Pro
Win XP
4GB
Old 06-07-2011, 02:49 PM
albee1952 albee1952 is online now
Default Re: Roland TD 4ks ...?
As long as it can send out midi, it should be fine. I use a TD-10 kit with ezdrummer and it rocks.
Old 06-13-2011, 11:41 AM
Awesome!!! Looking forward to setting it up. Is it hard? Doesn't explain how to "synch" the kit to ezdrummer or strike (it will work with strike as well, right?). Is it plug and play, so it recognizes it right away?
TDub
Intel Quad Q9550
Asus P5Q Pro
Win XP
4GB
Old 06-16-2011, 11:13 AM
I can't speak for Strike, but ezdrummer and SD2 are mapped almost perfectly right out of the box. Assuming Roland has used the same note assignment (and I don't see why they would change it), you should be 98% good with your first attempt. Where it gets a little tricky is if you have an AUX trigger that you want to use for side stick or cowbell. That will take a bit of fishing for the correct midi note(on the Roland brain). In any case, kick, snare, hat, toms and cymbals worked for me from day one
patches for roland xp-30 and roland gr-20 orlando Santos MIDI 2 10-29-2011 03:19 PM
Roland SI-24 JaxMan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-21-2005 09:03 AM
Roland RPC-1 with PTF? Billy Mayhem Digidesign Hardware & Software 0 08-13-2004 08:47 PM
Roland TD6 set-up joelc73 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-05-2003 10:02 AM
Roland DS 50 tucum 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-12-2001 09:34 AM
