Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 04-30-2011, 11:18 AM
CalebB CalebB is offline
Default Tell Strike to receive midi channel 2 ?!!
I would like to only play the individual single drum hits in Strike using a drum pad controller (AKAI MPD18). I do not want to trigger any loops. I understand that I need to use midi channel 2 in Strike to achieve this but I have no idea how to tell Strike to receive midi channel 2.
I have searched the manual and the web for about an hour to no avail. I realize this is probably very simple but please someone explain it to me!!
Thanks!
Old 04-30-2011, 03:10 PM
Default Re: Tell Strike to receive midi channel 2 ?!!
Am curious as well, but from recent history, drum/percussion usually uses midi channel 10
Old 04-30-2011, 03:49 PM
Try the MIDI Output Selector of an Instrument track.
Aaron Mulqueen - 001 HD Native
Old 04-30-2011, 04:17 PM
Okay, I tried something new and fixed the issue! I went to Pro Tools LE "Preferences" and went to "MIDI" and changed "Default Thru Instrument" from whatever it was to Strike 1-2 (channel 2 I guess).
Is this what every other thread assumes we are all supposed to know? (I rarely use MIDI so this could have been a common assumption that most people already know).
Old 04-30-2011, 04:40 PM
No, that is Default Thru Instrument meaning you can trigger the assigned Instrument and Channel without Record Enabling. I gave you the answer.
Old 04-30-2011, 04:48 PM
Thanks filosofem. I didn't see your post until now. I had tried creating a MIDI track and sending an output to Strike Channel 2 but the option for Strike was grayed out (not available).
After I changed the preference I am able to select Stike's different channels.
Old 04-30-2011, 04:51 PM
Use an Instrument track. If you are going to use a MIDI track you also need an audio carrier and a MIDI Node and this is provided via an AUX track but as I said use an Instrument track. Don't forget to put Strike in Kit mode too.
Strike can't receive MIDI from my AKAI MPD18 CalebB Virtual Instruments 0 10-22-2012 03:21 PM
PT to Receive Midi channel data from MPC weswook 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-06-2009 05:27 PM
Strike! - unexpected MIDI channel change edgarbc1 Virtual Instruments 2 02-03-2009 03:19 PM
Change a MIDI input channel for Strike WRETAUDIO 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-02-2007 05:33 AM
Changing MIDI channel for strike WRETAUDIO 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-01-2007 01:37 PM
