Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 04-23-2011, 03:26 AM
Hamdi Hamdi is offline
Default Need advice on overdubbing midi drums parts
I'm recording the drums using midi keyboard controller using Superior Drummer 2.2.3.with PTHD8.
Say I record bass drum and snare drum part and later add hi hat, cymbal crash or toms fills, recording over the existing parts.
Thanks
Old 04-23-2011, 07:45 AM
Default Re: Need advice on overdubbing midi drums parts
You need to make a choice here. If you use Midi Merge, so you can play one part at a time, then overdubbing is not so easy. To overdub, you would normally NOT use midi merge, so that the new playing over-writes the old. I would suggest getting your parts close in recording, and then editing the midi. Its rather easy to move midi notes around, remove some or add new ones with editing.
Old 04-23-2011, 08:03 AM
nst7 nst7 is offline
The midi merge button is in the main transport window. It looks like 2 arrows that become one. When this is pressed (lit up in blue), then you can keep adding to what you've already done (as in, you do kick, then go back and add snare, then hi hat, etc.).
When this button is off (not lit up in blue), then it behaves like it's an audio track, where each time you go back, it erases what you did.
For what you're trying to do, you want to have midi merge on. You can go back later and move or edit the notes, as Albee mentioned.
Need help moving parts (PT and Addictive Drums) nickbunyun Pro Tools M-Powered (Win) 2 07-19-2010 09:53 AM
Committing midi parts to audio. All parts ahead of bar line sad1robot Pro Tools TDM Systems (Mac) 2 04-25-2010 01:09 AM
Delay comp when overdubbing drums? RKrizman Pro Tools TDM Systems (Mac) 161 07-23-2009 04:52 PM
need some advice on these parts for a new system floydian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-18-2009 09:07 AM
MIDI V-Drums advice rtm MIDI 4 04-15-2009 08:51 PM
