Old 03-19-2007, 02:44 PM
Delta Music Belgium's Avatar
Delta Music Belgium Delta Music Belgium is offline
Default \"Buss error\" in thread \"MainThread\" at adress 0xbffe-nnn
When using Structure beta I do get a lot of crashes that show "Buss error" in thread "MainThread" at adress 0xbffe-nnn (nnn are different numbers and/or letters each time, f.e.'3a0' or '6c0', etc...)
It happens when:
- instanciating more then one instance of Structure
- alt-dragging an instance of Structure from an instrument channel to another
- opening a session with more then one instance of Structure
- changing parameters in Structure
Sometimes when more then one instance of Structure is used and I try to change something (f.e. a MIDI channel) Pro Tools starts to play a few MIDI notes by itself (without me pressing the 'play' button) and loops infinitly. Pressing 'stop' does not work, only Pro Tools quitting in the Finder helps. The closing screen also shows "Buss error" in thread "MainThread" at adress 0xbffe-nnn
Marc Schellekens
Delta Music - Pro Tools HD Mix & Mastering Suite - Belgium
PT HD 7 ACCEL system details:
Mac G4 Dual 1.25 GHz (FW800) + 2 GB RM + ATTO UL3D
OS X 10.4.9 + PT HD 7.3.1cs2 + Logic Pro 7.2.3
PT HD 7 Accel (1 x HD Core PCI + 6 x HD Accel PCI) inside 7-slot 64 bit Digidesign PCI Exp. Chassis
192 I/O + AD expansion card + 192D I/O + SYNC I/O + MIDI I/O + ProControl + Avid Mojo
Marc Schellekens
Delta Music Belgium - Dolby Atmos Music Studio
https://www.deltamusic.be
Mac Pro 2019 - 3.2GHz 16-core - 96GB RAM - macOS 14.4.1 - PT HDX3 - Pro Tools Ultimate 2024.3.1 - Avid HD I/O 16x16 (x2) - Avid HD I/O 16x16 Digital - Digidesign 192 I/O - Digidesign 192D I/O (x3) - Avid SYNC HD - Apogee Big Ben - Apogee Rosetta 200 - Avid S3 - Slate RAVEN MTi2 (x2) - iConnectivity mioXL (x4) - Genelec ‘The Ones’ 9.1.6 Dolby Atmos Music monitoring (AES/EBU) with 8341A (x5) + 8331A (x10) + 7360A (x2) + 9301B - Almost all available AAX-DSP plug-ins
Old 03-22-2007, 06:29 AM
Wolfram K's Avatar
Wolfram K Wolfram K is offline
AIR Music Technology
Default Re: \"Buss error\" in thread \"MainThread\" at adress 0xbffe-nnn
Thanks for reporting, this behavior is under investigation.
Wolfram K
pt 10.3.2. crashes when saving | "bus error" in thread Mainthread… johannes1 Pro Tools 10 8 05-02-2013 06:28 PM
"segmentation fault" in thread "Main Thread" , at adress 0x0 melvindesk Tips & Tricks 0 06-13-2012 06:17 PM
Bus error in thread "mainthread", at address 0x0 - when opening a session skote 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-08-2011 08:11 AM
Pro tools 9 crashes at startup "Bus error" in thread "MainThread", at address 0x0 danball macOS 2 09-26-2011 04:49 PM
Buss Error in Main Thread at address oxo garnoil macOS 3 01-01-2011 05:24 AM
