Old 12-01-2004, 01:03 PM
bassntreble bassntreble is offline
Default can I run two versions of PT...
on my machine concurrently?
basically I want to upgrade to 6.7 but I can't have the bugs of this release impeding my workflow (eg, the issue with pluggo crashing PT6.7).
So my question is can I have 6.4 and 6.7 installed (not running) at the same time and will I be able to switch between them? Or are there other system or user level lib's or files involved that get modified which would render 6.4 incompatible if 6.7 is installed?
thanks in advance..
G5 1.8X2/3gigRAM/Mbox/7.4 (retired)
MBP C2D 2.4/4GigRAM/Mbox/8.0.1
iMac i7 3.4/16GigRAM/10.0.1
Old 12-01-2004, 01:30 PM
Ducky Ducky is offline
Default Re: can I run two versions of PT...
Can you run a dual boot system with MAC?
For Windows XP, XP needs it's own disk partition, but it definitely keeps two versions of PTLE separated.
Different card versions according to PT versions? ambidextrous.PR Pro Tools TDM Systems (Mac) 3 12-21-2013 03:08 AM
Different PT versions on one Mac? firehouserecording macOS 37 02-09-2013 01:32 AM
Two Versions for a while johnwesleybarker Pro Tools M-Powered (Mac) 0 01-23-2009 03:04 AM
2 OSs & 2 PTs versions on one G4? suiteaudio Pro Tools TDM Systems (Mac) 2 08-05-2007 11:37 PM
DUY OSX versions now available Xavi - DUY Tips & Tricks 0 03-12-2003 02:54 PM
