Old 06-07-2019, 02:12 PM
Markrosoft Markrosoft is offline
Default Plugin Window Disappears if I select another Track
Either updating to 2019.5 or deleting my preferences is causing something I've never experienced: if I open a plugin window and then just select a different track (NOT another plug-in, but literally just select another TRACK) the plugin window I opened disappears.
So, just to make this clear... I open Kontakt on a track called Piano. Then I just click on a track called cello and my Kontakt piano disappears.
This never used to happen and for the life of me can't find where the setting is to change this back to the normal behavior - a plugin window stays open until you close it or open another plugin. I know I can click the red box to leave the plugin open but again, I'm looking to return it to the default behavior.
Does anyone know where this preference can be changed?? Thank you for your help!!
Old 06-07-2019, 02:47 PM
BScout BScout is offline
Default Re: Plugin Window Disappears if I select another Track
It has to do with Eucon. Do you use a Eucon controller (is it turned on in Peripherals)? There are a lot of options now on how plugin windows (and pan and send and etc.) operate when a track is brought to attention.
You just need to go through them to find what works for you in Eucontrol.
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 06-09-2019, 08:12 AM
Thank you - you are totally right. For anyone else coming across this problem, you just go into EuControl Settings -> General -> and then unclick "Close Windows on Workstation When Exiting."
Thanks again BScout.
Keyboard shortcut to arm/select next midi track in mix window ronwasserman Pro Tools 12 2 01-25-2018 01:32 PM
Plugin window follow select? jasenj1 ICON & C|24 2 10-08-2014 07:39 AM
No "Select Next Track" key command for mix window? Benny_Cha_Cha Pro Tools 11 3 08-17-2014 07:38 AM
Is there a way to automatically bring a track you select into view in the edit window Focuret Artist Series 4 01-05-2013 01:48 PM
clicking Apple + Auto on a track plugin window Pete Gates Pro Tools TDM Systems (Mac) 1 11-09-2005 10:47 AM
