Old 05-10-2019, 11:25 AM
kkfaudio kkfaudio is offline
Default Lock to Pro Tools check box gone?
Missing the ability to keep Eucon Focussed on PT - when I send a clip over to Rx the artist mix faders all go to zero, and then have to re-set when I bring the clip back.. It all seems to come back fine, but it's causing wear and tear and abrupt noises...
Is it option hiding somewhere new?
Thanks..
Kevin Ferrier
Audio & Sound Design
www.trianglepost.com
Old 05-10-2019, 11:51 AM
BScout BScout is offline
Default Re: Lock to Pro Tools check box gone?
It's where it always has been.
Go to the Assign tab in Eucontrol and at the bottom.
Make sure pro tools is in focus first and then click "Entire Surface" and it will say it is locked to Pro Tools.
(You can tell if Pro Tools is in focus on that same tab because at the top where it says "Application:" it will say it to the right if it is in focus.)
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 05-10-2019, 01:21 PM
And this is why I shouldn't be trying to this on a Friday..
Of course I wouldn't have updated if I'd had my iPad not set to "auto update" the app...
thanks for the direction..
Kevin Ferrier
Lock surfaces to Pro Tools? Tim R. Pro Tools | S3 2 12-22-2015 07:23 AM
When oh when will we be able to "lock out" tools and modes?? Drew Mazurek Pro Tools TDM Systems (Mac) 34 01-09-2008 07:56 AM
2gb,check! firewire audio drive,check! samples.... bump!! MarkusB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-24-2007 02:25 AM
Pro Tools lock-up stickarms 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-23-2002 06:44 AM
Pro Tools Lock Up!!! Smakrabit Digidesign Hardware & Software 1 04-13-2002 01:45 PM
