Copy/Paste Automation of Multiple parameters
Anyone having problems with this? My troubleshooting has indicated the following:
On a new session, it works at first paste and then there seems to be a clipboard issue and if I try to do it on copy automation and paste, the result is automation from the last copy. Another interesting thing is that if you copy automation across parameters (control command c) it does not show in the undo history window. The other companion key commands still work ... control command d and control command x, etc. Seems like this started not working properly in 6.7. Thoughts? |
Re: Copy/Paste Automation of Multiple parameters
i wonder if pro tools doesn't empty the clipboard properly if this happens only as the session goes on.
If you don't like laughing at yourself, I will be happy to do it for you. Da-nick-str = Nick Dellos |
Copy and Paste multiple tracks at once | roxburyband | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 08-23-2017 11:12 AM |
Help: copy/paste plugin parameters (ex: 2.0 to 5.1)? | Floydio | Tips & Tricks | 2 | 05-26-2010 02:04 PM |
Shuffle doesn't shift volumes - copy & paste doesn't copy automation | marcnyc | Pro Tools TDM Systems (Mac) | 2 | 03-12-2010 12:46 AM |
How do you copy & paste across multiple tracks? | meister | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-13-2007 08:36 PM |
Copy/Paste Automation of Multiple parameters | noizgirl | Tips & Tricks | 0 | 01-21-2005 03:46 PM |
