Old 03-30-2014, 05:36 AM
Alouise Alouise is offline
Default digitest failed - need help
Hi
I just ran a digitest because my pro tools 10.3 and 11 is behaving very strange, randomly playing back recorded audio with an unintentional high cut. The same file will be fine one minute and play without high end the next.
The test said:
Test says:
All test have completed
Total run time 7:35 min
Status failed
Peripheral Loopback test connector 1 Pri --- failed – Data missing or invalid: Group 1 Group 2
Peripheral Loopback test connector 2 Pri --- failed – Data missing or invalid: Group 1 Group 2
Peripheral Loopback test connector 2 Sec --- failed – Data missing or invalid: Group 1 Group 2
All others passed
Anyone knows how to fix this?
Thanks!
Old 03-30-2014, 05:49 AM
Default Re: digitest failed - need help
I am running with 2 aurora16HD, are they the reason for the loopback failure? and if so, should I worry or just accept it as, not a part of the real problem?
Old 03-30-2014, 09:30 AM
Chief Technician Chief Technician is offline
Lightbulb Re: digitest failed - need help
That's a question for Aurora. The only way to be certain your cards are OK would be to test them with an Avid interface connected.
Jonathan S. Abrams, CEA, CEV, CBNT
Apple Certified - Technical Coordinator (v10.5), Support Professional (v10.6 through v10.10)
Old 03-30-2014, 09:34 AM
Maybe run the test with only 1 Aurora connected, then repeat with only the other connected(and use the primary port each time)
Old 06-07-2020, 03:55 PM
thigohdx thigohdx is offline
Hi
The test said:
Test says:
Status failed
All others passed
Thanks!
Hi... did you find yhe issue? Having the same but with 2 avid HD and 2 Digi 192
Best
Old 06-07-2020, 05:09 PM
crizdee's Avatar
crizdee crizdee is offline
Best
This post is 6 years old, would have been better to start your own post. but as you're here...
Have you stripped the system back to just the core card and one interface and run the test. Then add one process card and flex cable and test again and keep adding stuff till the problem persists etc. could be one of the cards or a flex cable that connects betwen the cards. process of elimination change and swap the components to find what is causing the issue.
Chris
Producer, Engineer,
www.ukmastering.com
All of my cards failed the digitest bernisava Tips & Tricks 14 01-08-2011 08:51 PM
digitest failed pipolito Pro Tools TDM Systems (Mac) 2 03-28-2010 02:07 PM
Failed Digitest Buffstuffbuddha Tips & Tricks 4 05-07-2009 02:48 PM
Digitest failed on AudioMedia III jar.w Digidesign Hardware & Software 2 06-06-2006 03:45 PM
Digitest "failed test 185" Inkfish Productions Pro Tools TDM Systems (Mac) 1 08-01-2000 12:02 AM
