Old 02-09-2010, 10:28 PM
sad1robot sad1robot is offline
Default Midi Regions / Losing the first midi note when duplicated
Midi Regions / Losing the first note when duplicated.
here is my situation:
I have a 2 bar midi region of notes triggering a an Akai s950
with slices of a drum break. ( Old school style of Recycle / pre Rex file player)
every time i copy the midi region to a different location the First midi note inthe copied region is always missing. This is annoying. Why is it doing this ???where and why isnt that note making the move? Frustrating . whats the Logic behind this? Do i have a preference setting that needs to be set to turn this annoying feature off?
why dont midi regions just copy like the audio?
ill crack the Pdf manual. but if someone knows how to get around this id appreciate some help
Old 02-10-2010, 01:25 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Midi Regions / Losing the first midi note when duplicated
Is the first note definitely quantized on the grid?
How are you quantizing the midi? real-time midi?
Using the real time properties window have you used "write to region" to convert to non real-time quantize.
are you in tick based tracks or samples?
Chris
Producer, Engineer,
www.ukmastering.com
Old 02-10-2010, 11:39 AM
doopadee doopadee is offline
Most likely, the first midi note is placed BEFORE the grid marking. Quantize just that one note so that it begins within the bars you are copying. If you don't want to quantize the note because it changes the feel, then just make your 2 bar selection starting at or before your first note.
Adam Miele
Pulse Music NYC
212-358-7900
[email protected]
Old 02-10-2010, 11:44 AM
soundboy35 soundboy35 is offline
If that first note is even the tiniest bit early on the grid, it won't copy or duplicate.
You have to really zoom in sometimes to check it.
I still don't understand why when using MIDI region view, and you cut on the grid,
it doesn't split that bad note. Maybe the "trim to start" feature? I have seen where
you quantize a note, and it still precedes the grid enough to not copy.
MacBook Pro 15in, 2.3gHz,i7
PT 2021.x
PT12.8.x
Old 02-10-2010, 01:23 PM
Intransit Intransit is offline
I have this same problem even when the note is on the grid. This has been driving me crazy for years. I'm a composer and midi is a HUGH part of what I do. Nothing I have tried fixes this. I have to use the grabber tool to circle in my selection then move it over holding option. It sucks. For years this has been a work flow mystery. I would love to know the logic behind this too.
Oh... Ticks or samples same problem.
iMac Retina 5K, 2020, 3.6 GHz 10-Core Intel Core i9, RAM 72GB
HD Native PCIe card /// OWC Mercury Helios 3S
PT 24.3.0
Old 02-10-2010, 02:22 PM
The only way I've been able to fix this when there are notes preceding a bit, is to go to notes view in grid mode,
select the area to duplicate or copy with the selector tool, and "trim to selection" (Command T), then duplicate, etc.
Sometimes it looks like the note is on the grid, but when zoomed in enough, you will see a tiny piece that precedes.
Why it won't quantize correctly in the first place is anybody's guess....
PT 2021.x
PT12.8.x
Old 02-10-2010, 05:04 PM
tonwurm's Avatar
tonwurm tonwurm is offline
consolidating the region (shift alt 3) seems to fix this issue
MP5,1 12core 3.46ghz 96GB
Ultimate HDX
https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ
Old 02-10-2010, 05:06 PM
tonwurm's Avatar
open the midi editor window and place the cursor at the desired start postion an hit 'trim to start'
Ultimate HDX
Old 02-10-2010, 05:40 PM
I'm using 7.4, but the Trim to Selection seems to work.
PT 2021.x
PT12.8.x
How do I UNlink a duplicated midi track from it's source? brandobean MIDI 3 07-26-2016 11:02 PM
Digi MIDI i/o Duplicated and greyed in Audio/Midi setup xxicjoy MIDI 69 08-02-2013 08:40 PM
Midi 101 really missing? Set high note/low note on track's input robinsonsdca macOS 4 11-10-2011 01:23 PM
Editing note in Looped Midi Regions tele27 Pro Tools TDM Systems (Mac) 3 05-31-2011 07:03 AM
EXPORT MIDI from Stryke NOTE FOR NOTE... riggi Virtual Instruments 1 03-10-2008 07:32 PM
