Old 04-25-2019, 03:46 PM
Scott G Scott G is offline
Default Importing multichannel wav?
I have a project coming up using a Sound Devices 688. It will record in a multichannel format as well as recording each channel on it's own wave file. If the project ends up being recorded as a polyphonic .wav file can I just drag it into PT or do I need to convert it somehow? Running PT 12.6 native non HD.
Thanks
Scott
Auckland New Zealand
PT12.7.1 SSL MX4, SSL Alpha-Link MADI-SX
HP Z240 Workstation, I7-3770 3.4GHz, 32GB RAM, Win10 Pro 64bit
Old 04-25-2019, 04:36 PM
Vedat's Avatar
Vedat Vedat is offline
Quiet Art Ltd.
Default Re: Importing multichannel wav?
You should be able to import poly files no problem.
I can't imagine it being an HD only feature.
Vedat
Check out WaveRider + Defaulter:
QuietArt.co.nz
Catchin' SYNC app
Old 05-14-2019, 04:19 AM
Led Led is offline
I think multichannel is HD only, although I don't have a version I can check on. If you can't, sound devices wave agent can split multi's into mono files then you could import into PT12. It's free I believe.
https://www.sounddevices.com/product/wave-agent/
Old 05-14-2019, 07:15 AM
QuikDraw QuikDraw is offline
Yes, it is an HD only feature.
I use Studio One for this; Presonus doesn't charge extra to import audio!
-- Mike
- MacBook Pro 15.4" (9,1) - 2.3 GHz i7 16GB RAM
- OS X 10.14.1 Mojave / Windows 10 (Bootcamp) - PT running on Windows partition
- PreSonus Quantum 2
- PreSonus Studio 24c
- MBox 3 Mini
- Mackie Onyx 1640i
- Behringer X32 Producer
- PT 2018.12 (vanilla)
- Various USB2/3 and Firewire hard drives
Old 05-14-2019, 03:27 PM
It turned out last Friday I was able to import the multichannel file directly into PT12.6 non HD by dragging it into the session. In the end I ended up recording on a Sound Devices 788.
Scott
Old 05-15-2019, 04:52 AM
Led Led is offline
Scott, what did you do with it once you imported..were you able to split it into 6x mono?
Old 05-15-2019, 03:31 PM
I setup 10 mono tracks in PT and just dragged the .wav file onto the edit window and it split them out dropping one onto each track.
Just for laughs I tried it with an old version of Adobe Audition v3 I had and that worked the same. However Tracks Live gave me an import error.
Scott
Old 05-15-2019, 03:35 PM
Led Led is offline
Niiice, Good to know it can do it.
Old 05-16-2019, 03:39 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
If nothing else works.
IMDB
HTML code is On
Importing Multichannel interleaved .wav file into Protools 9 AndoNaught Pro Tools 9 2 11-29-2018 12:09 PM
No multichannel EQ? Numi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-23-2008 05:30 PM
Multichannel tracks? JonesH 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-15-2008 04:00 AM
Any recommendations for a multichannel amp? anodecathode Pro Tools TDM Systems (Mac) 11 06-06-2004 05:36 PM
Multichannel panner in PT 5.1? DigiTechSupt Pro Tools TDM Systems (Mac) 4 04-10-2002 12:42 PM
