Old 02-09-2010, 06:29 PM
travis_123 travis_123 is offline
Default Error 9093 & 9092 please help!!
Well first of all tell them to do this post before I had the time to investigate several hours inside the forum to see solutions to this problem able to find different solutions, but unfortunately not a me a result
Reading the rules of the forum understood the subject of report Sandra so I installed the program and perform the analysis.
Well my problem is that when connecting the microphone and start recording achievement record around 20, sometimes 30 seconds is even more concerning, but after a while I lock the program and sometimes throws me error 9092 or 9093, in the event that this mixing a topic if I have the buffer in 512 throws me problems, it is only when under the buffer to 64 and turn on the microphone where the problems begin beforehand thank you very much and I hope I can help.
I use Pro Tools 8.0 LE with Mbox 2 Mini and a Rode NT1-A Mic
The other thing we apologize if my writing is very understandable thing is that I am of chili where the language is Spanish so I had to do a Google translation greetings hope all understand me.
< Processor >
Model: AMD Phenom(tm) 9600 Quad-Core Processor
Speed: 2.29GHz
Model Number: 6885
Cores per Processor: 4 Unit(s)
Threads per Core: 1 Unit(s)
Type: Quad-Core
Internal Data Cache: 4x 64kB, Synchronous, Write-Back, 2-way, 64
byte line size
L2 On-board Cache: 4x 512kB, ECC, Synchronous, Write-Back, 16-
way, 64 byte line size
L3 On-board Cache: 2MB, ECC, Synchronous, Write-Back, 32-way, 64
byte line size, 4 threads sharing
< System >
System: MICRO-STAR INTERNATIONAL CO.,LTD MS-7501
Mainboard: MICRO-STAR INTERNATIONAL CO.,LTD MS-7501
Bus(es): ISA PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support: 1 Processor(s)
Multi-Processor Advanced PIC (:Yes
System BIOS: American Megatrends Inc. 8.15
Total Memory: 3.25GB DDR2
< Chipset 1 >
Model: AMD ??? (9600)
Front Side Bus Speed: 1x 200MHz (200MHz)
< Chipset 2 >
Model: AMD (Family 10h) Athlon64/Opteron/Sempron
HyperTransport Technology Configuration
Front Side Bus Speed: 2x 1.8GHz (3.60GHz)
Total Memory: 4GB DDR2
Memory Bus Speed: 2x 267MHz (534MHz)
< Video System >
Monitor/Panel: Monitor Plug and Play
Adapter: ATI Radeon HD 3200 Graphics
< Physical Storage Devices >
SAMSUNG HD320KJ 320GB (SATA300:298.09GB (C:) (D:)
SAMSUNG HD250HJ 250GB (SATA300:232.89GB (F:)
ATAPI DVD A DH20A4P (ATAPI66,:N/A (E:)
< Logical Storage Devices >
Hard Disk (C:): 39.30GB (23.97GB, 61% Free Space) (NTFS) @
SAMSUNG HD320KJ 320GB (SATA300, NCQ, 8MB
Cache)
Hard Disk (D:): 258.79GB (189.52GB, 73% Free Space) (NTFS) @
Cache)
Hard Disk (F:): 232.87GB (229.32GB, 98% Free Space) (NTFS) @
SAMSUNG HD250HJ 250GB (SATA300, NCQ, 8MB
Cache)
CD-ROM/DVD (E:): N/A @ ATAPI DVD A DH20A4P (ATAPI66, 48x CD-R,
48x CD-W, 6x DVD-R, 6x DVD-W, 2MB Cache)
< Peripherals >
Serial/Parallel Port(s): 1 COM / 0 LPT
USB Controller/Hub: Controlador de host de PCI a USB mejorado
USB Controller/Hub: Controladora de host USB OpenHCD estándar
USB Controller/Hub: Concentrador raíz USB
USB Controller/Hub: Dispositivo compuesto USB
USB Controller/Hub: Digidesign Mbox 2 Firmware Updater
FireWire/1394 Controller/Hub: Fabricante de la controladora de host
compatible com OHCI IEEE 1394
Keyboard: Dispositivo de teclado HID
Mouse: Mouse compatible con HID
Human Interface: Dispositivo de control del consumidor
compatible con HID
Human Interface: Dispositivo compatible con HID
Human Interface: Dispositivo de interfaz humana USB
< Printers and Faxes >
Model: Microsoft XPS Document Writer
< Power Management >
Mains (AC) Line Status: On-Line
< Operating System(s) >
Windows System: Microsoft Windows XP (2002) Professional
5.01.2600 (Service Pack 3)
Platform Compliance: Win32 x86
< Network Services >
Adapter: Realtek RTL8168C(P)/8111C(P) PCI-E Gigabit
Ethernet NIC
Adapter: D-Link Wireless G DWA-510 Desktop Adapter
< Performance Tips >
Warning 100: Large memory sizes should be made of
Registered/Buffered memory.
Tip 2546: Large memory modules should be ECC/Parity.
Tip 2: Double-click tip or press Enter while a tip
is selected for more information about the
tip.
<<< Mainboard >>>
< System >
Manufacturer: MICRO-STAR INTERNATIONAL CO.,LTD
Model: MS-7501
Family: To Be Filled By O.E.M.
Version: 1.0
Serial Number: To Be Filled By O.E.M.
SKU Number: To Be Filled By O.E.M.
< System Chassis >
Type: Desktop
Can be locked: No
Version: 1.0
Power Cord(s): 1
Asset Tag: To Be Filled By O.E.M.
Boot-up State: Safe
Power State: Safe
Thermal State: Safe
Security State: External Interface Locked-out
< Mainboard >
MPS Version: 1.40
Model: MS-7501
Type: Mainboard
Version: 1.0
Serial Number: To be filled by O.E.M.
Location in Chassis: To Be Filled By O.E.M.
System BIOS: 64-0100-000001-00101111-012109-ATHLON64
< System Mainboard Properties >
Removable: No
Replaceable: Yes
Hot Swap: No
< On-board Devices >
To Be Filled By O.E.M.: Video Adapter (Enabled)
< System Memory Controller >
Error Correction Capability: None
Number of Memory Slots: 4
Maximum Installable Memory: 8GB
BANK0 - DIMM0: Manufacturer0 PartNum0 SerNum0 AssetTagNum0
DIMM Synchronous DDR2 1GB/64 @ 266MHz
BANK1 - DIMM1: Manufacturer1 PartNum1 SerNum1 AssetTagNum1
DIMM Synchronous DDR2 2GB/64 @ 266MHz
BANK2 - DIMM2: Manufacturer2 PartNum2 SerNum2 AssetTagNum2
BANK3 - DIMM3: Empty
< Chipset 1 >
Revision: A1
Bus: HyperTransport
In/Out Width: 16-bit / 16-bit
Maximum Bus Bandwidth: 800MB/s
< Chipset 2 >
Revision: A1
Bus: HyperTransport
Version: 3.00
Maximum FSB Speed: 2x 2.60GHz (5.20GHz)
I/O Queue Depth: 12 request(s)
Maximum Bus Bandwidth: 14.06GB/s
< Chipset 2 Hub Interface >
Type: HyperTransport
Version: 3.00
< Logical/Chipset 2 Memory Banks >
Bank 0: 1GB DDR2 4.0-4-4-12 CR2
Bank 2: 512MB DDR2 4.0-4-4-12 CR2
Bank 3: 512MB DDR2 4.0-4-4-12 CR2
Bank 8: 1GB DDR2 4.0-4-4-12 CR2
Bank 9: 1GB DDR2 4.0-4-4-12 CR2
Supported Memory Types: ECC Registered DDR2 DDR3
Channels: 2
Bank Interleave: 2-way
Maximum Memory Speed: 2x 400MHz (800MHz)
Multiplier: 4/3x
Width: 64-bit
Memory Controller in Processor:Yes
Cores per Memory Controller: 4 Unit(s)
Refresh Rate: 7.80µs
Power Save Mode: No
Fixed Hole Present: No
Maximum Memory Bus Bandwidth: 8.34GB/s
< APIC 1 >
Version: 2.01
Maximum Interrupts: 24
IRQ Handler Engaged: Yes
Enhanced Support: Yes
< Environment Monitor 1 >
Model: Fintek F71882F/FG LPC
Mainboard Specific Support: No
< Environment Monitor 2 >
Model: AMD K8 F10 CPU [P0]
Version: 2.02
< Temperature Sensor(s) >
CPU Temperature: 38.00°C td
Auxiliary Temperature: 36.00°C td
< Cooling Device(s) >
Auto Fan Speed Control: No
System Fan: 3580rpm
< Voltage Sensor(s) >
CPU DC Line: 1.26V
+3.3V DC Line: 3.31V
Standby DC Line: 3.33V
Battery DC Line: 3.25V
< PCI Bus(es) on Hub 1 >
Version: 2.30
Number of Bridges: 4
PCI Bus 0: PCI (1/1x PCIClk)
PCI Bus 1: PCI (2/1x PCIClk)
PCI Bus 2: PCIe (3/1x PCIClk)
PCI Bus 3: PCIe (3/1x PCIClk)
PCI Bus 4: PCI (1/1x PCIClk)
Number of PCIe Lanes: 2
< LPC Hub Controller 1 >
Model: MSI IXP SB600 SMBUS Controller
Revision: D11
ACPI Power Management Enabled: Yes
High Precision Timer Support: Yes
High Precision Timer Enabled: No
< LPC Hub Controller 2 >
Model: MSI ??? (439D)
Revision: A1
< USB Controller 1 >
Model: MSI ??? (4397)
Revision: A1
Version: 1.00
Interface: OHCI
Channels: 3
Supported Speed(s): Low (1.5Mbps) Full (12Mbps)
Legacy Emulation Enabled: No
< USB Controller 2 >
Model: MSI ??? (4398)
Revision: A1
Version: 1.00
Interface: OHCI
Channels: 3
< USB Controller 3 >
Model: MSI ??? (4396)
Revision: A1
Version: 2.00
Specification: 1.00
Interface: EHCI
Channels: 6
Companion Controllers: 2
Supported Speed(s): Low (1.5Mbps) Full (12Mbps) High (480Mbps)
Addressing Support: 32-bit
< USB Controller 4 >
Revision: A1
Version: 1.00
Interface: OHCI
Channels: 3
< USB Controller 5 >
Revision: A1
Version: 1.00
Interface: OHCI
Channels: 3
< USB Controller 6 >
Revision: A1
Version: 2.00
Specification: 1.00
Interface: EHCI
Channels: 6
< USB Controller 7 >
Model: MSI ??? (4399)
Revision: A1
Version: 1.00
Interface: OHCI
Channels: 2
< FireWire/1394 Controller 1 >
Model: MSI ??? (2380)
Revision: A1
Version: 1.10
Interface: OHCI
Enhanced Support: No
Channels: 64
Speed: 400MHz
< System SMBus Controller 1 >
Model: ATI AFS SMBus
Specification: 1.00
Advanced TCO Mode Enabled: Yes
Slave Device Enabled: No
PEC Support: No
Speed: 10kHz
< Port Connector(s) >
J1A1 - PS2Mouse: Mouse / PS/2
J1A1 - Keyboard: Keyboard / PS/2
J2A2 - USB1: USB / USB
J2A2 - USB2: USB / USB
J2A1 - COM A: Serial Port 16550A / DB-9 pin male
J6A1 - Audio Mic In: Audio / Mini-jack
J6A1 - Audio Line In: Audio / Mini-jack
J6A1 - Audio Line Out: Audio / Mini-jack
J6B1 - AUX IN: Audio / CD-ROM Sound Input
J6B2 - CDIN: Audio / CD-ROM Sound Input
J6J2 - PRI IDE: ATA
J6J1 - SEC IDE: ATA
J4J1 - FLOPPY: Floppy Disk
J9H1 - FRONT PNL: 9 Pin Dual Inline
J1B1 - CHASSIS REAR FAN: None
J2F1 - CPU FAN: None
J8B4 - FRONT FAN: None
J9G2 - FNT USB: None
J6C3 - FP AUD: None
J9G1 - CONFIG: None
J8C1 - SCSI LED: None
J9J2 - INTRUDER: None
J9G4 - ITP: None
J2H1 - MAIN POWER: None
Warning 2533: Disabled host controllers are present. Check
BIOS settings.
Notice 224: SMBIOS/DMI information may be inaccurate.
Tip 2511: Some memory slots are free so the memory can
be easily upgraded.
tip.
Old 02-09-2010, 07:24 PM
cwsand's Avatar
cwsand cwsand is online now
Default Re: Error 9093 & 9092 please help!!
Hi, if I understand correctly you are getting Hardware Buffer error's when under 512? Have you done all the optimizations described in the General Troubleshooting thread?
Help Us Help You
Chris
__________________________________________________
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Gigabyte GA-Z170-HD3P / i7 6700K 4.1 GHz / 32GB Crucial DDR4
macOS High Sierra Version 10.13.6
Pro Tools HD 2019.6
Old 02-09-2010, 08:02 PM
Mira will explain a bit more into the problem in Pro Tools if I select the option Ignore Errors, I obviously throws the error but what happens is that when you are recording several seconds after either 30 or 40 seconds it locks a little audio while still sounding audio, tracks, etc.. but making was being recorded is only up to the point where the audio is locked (another detail is that when this happens the part where you see the seconds that they run is stopped but still the audio as mentioned above)
This problem happens to me as it locks when I'm mixing but only if this buffer of 64 clear to me that if you mix it when you need to increase the buffer so in that case I think it is understood that throw errors when you are in 64 the buffer.
Well I hope to be governess to a little more explained my problem thoroughly so that you can understand a little more greetings to all.
9092, 9093 and 9129 error update? Mascola24 Pro Tools HDX & HD Native Systems (Win) 4 09-28-2011 07:10 PM
-9093 and -9092 error w/ BFD citychalkoutline 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-10-2008 10:24 PM
Pro tools 7.4 9092 and 9093 error Andreas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 11-30-2007 04:42 AM
Still getting error 9092 & 9093: "increase HW buffer size" pribb1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 22 07-07-2007 11:36 AM
error-9092 or 9093....whatever the hell it is, how can i get rid of it? moe green 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-20-2001 05:36 AM
