Old 06-13-2004, 06:19 PM
pelhamblue pelhamblue is offline
Default What happened to esb in 6.4?
Has anybody been able to make Logic Audio work with PT 6.4 and Panther? The esb seems to no longer work and none of my synths are able to play through my 192
Phil Hadaway
Old 06-14-2004, 03:03 AM
logicaltextures logicaltextures is offline
Default Re: What happened to esb in 6.4?
I would like to know what the deal is aswell, I havn't upgraded yet to Logic Pro but would like to know what I lose before I do. I had heard the HTDM enabler has been discontinued, ie. no evp88 / es2 comes up in Protools, but surely the esb is still available?!?!?
Thanks in advance...
Old 06-14-2004, 03:35 AM
M.K.BEAT M.K.BEAT is offline
Yes, no problems at all over here with PT 6.4, Logic Pro 6.4.2 and ESB/EXS24 TDM.
Do you have both plugins installed inside the Digidesign plugin folder?
All the best,
M.K.BEAT
Old 06-14-2004, 04:19 AM
debolish's Avatar
debolish debolish is offline
I am running two Logic Pro setups here:
1 - LP6.4.2/OS10.2.8/Mix3(DAE)/MOTU 828mkII(Core Audio)
2 - LP6.4.2/OS10.3.4/MOTU 828mkII(Core Audio)
I had experienced issues with ESB/DTDM on the Mix3 system - as have many others. ESB randomly stops working - sometimes reinserting cures it and sometimes a full quit and relaunch of Logic is required. As a workaround, I'm running DAE/Core Audio instead of DAE/DTDM completely avoiding ESB all together with. Audio is routed lightpipe from the 828 to an ADAT bridge. Completely stable.
You may want to do a search for ESB/DTDM on the Sonikmatter Logic Forums:
http://community.sonikmatter.com/cgi...ultimatebb.cgi
Beyond that - Logic Pro is solid.
Best of luck.
MacBook Pro 2.5 GHz i7 • 16 GB RAM • OS X 10.9.5 • PT 11.3
What happened to the...? Ludicrous Speed Pro Tools M-Powered (Win) 2 10-21-2005 07:45 PM
Need help!! never happened before DEEJAY 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-29-2005 03:47 PM
What happened to 5.2.1 ???? curve666 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-10-2003 07:09 PM
Has this happened to you? Logan M 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 12-08-2002 12:45 AM
What happened??? RLB Digidesign Hardware & Software 4 07-14-2002 08:16 PM
