Midi Sustain Problem in Pro tools 12
SOMEBODY HELP!!! Whenever I record long drawn out notes with my midi keyboard they sound fine and record. BUT! When I play back the recording the notes are short stacatto! What do I need to do?!
Re: Midi Sustain Problem in Pro tools 12
Can you verify whether or not Pro Tools is recording sustain info?
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (3) Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Try 'Remove Duplicate Notes' in the Event menu. If it corrects the playback, it could be that PT is seeing duplicate midi ports. This happens with certain midi interfaces. Untick the culprit in MIDI Devices, and the problem should stop if this is what is causing your issue. If this solves your problem, you should untick the duplicate ports whenever you trash your prefs.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
I am aware of this bug. It tracks fine, but on playback it does not work correct. Turn off the overlay (Midi Merge) option in the transport window. It works for me. But this bug does exist.
Hi all,
I'm new to the AVID tools and forum. I've been practicing music for over 40 years, but just recently bought the hardware to be able to record some of my songs, so this is fairly new to me. I'm having the same sustain issue in that I can hear the sustain when I record and I can see it visually on the track, however I do not hear it during play back nor when I export the song. The only time I can hear the sustain is when I hold down the sustain pedal. So the only solution so far is to hold down the sustain pedal indefinitely which doesn't give the best effect as you can imagine. I have looked through the Pro Tools manual and the online posts and have tried the "remove duplicate notes", using "midi merge options" (all options: Latch, Touch, or Latch until Next Event give the same result, whether midi merge is enabled or disabled). My have also tried playing around with the various midi and controller settings on the keyboard itself without success. However given that I can hear it well in ProTools, I don’t think the problem is with the instrument. My Interface: - Focusrite Scarlett 2i4 - Focusriteusbininstaller4.36.5-612 (latest) - AVID - Pro Tools First (v2018.7.0) Intruments/tools: - Yamaha W7 keyboard (attached through midi cables), this is an older keyboard. - Boss DR670 drum box (attached either through midi or jack for audio track) - Behringer, XM8500 mike (attached through standard jack) - Sustain pedal (standard Roland sustain pedal for pianos/keyboards) For some reason, Sandra Lite didn't work (giving me blank screens), so I uploaded a POC report from Everest in *.pdf. Any help would be greatly appreciated. Thanks Moe |
CMD-P (Mac) or Alt-P (PC) is where you find the settings for controlling your sustain pedal.
Nothing intuitive about it at all. Took me a lot off digging to find the simple answer. Hope this helps. |
I've tried COMMAND P and nothing happened? Also having the same problem on ProTools 2020.11.0. The sustain pedal works when recording but while it DOES record the sustain info, I'm not hearing it on playback. I'm playing the whole part with the sustain down, but when I play it back, the sustain info has been recorded but I'm not hearing it. I've manually switched the sustain on in the controllers tab, but it plays back as if it's off. The only way I can hear it is if I put it in record and play it back while holding down the sustain pedal.
Once again, thank you! |
This is the infamous "MIDI merge bug". Google for more info.
Problem with MIDI Merge on - sustain events | ChrisSimon | MIDI | 13 | 10-18-2017 02:57 PM |
Help midi sustain problem | weezamiah | MIDI | 3 | 05-21-2014 03:21 PM |
MIDI Sustain Problem In Playback | digijohn | macOS | 2 | 06-11-2013 06:27 AM |
MIDI sustain problem | djcream | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-30-2011 10:09 AM |
Problem with recording MIDI piano sustain pedal | Chris7514 | MIDI | 5 | 06-11-2008 12:56 AM |
