Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 11-11-2014, 10:48 AM
Armando Armando is offline
Default Problem w/Midi Over Lan with BFD2 and 2 Macs
Hello,
I've got my aging Pro Tools HD4 system(running PT HD 8) on a Dual 2Ghz G5 Power PC and BFD2 installed on a Quad Core i7 2.3Ghz Mac Mini.
i figured I would try the Midi Over Lan method on this set up.
After following directions for connecting both Macs over LAN which seems to have worked/connected, I can't register any midi data via BFD2 running on the Mac Mini in Standalone mode(triggered by Roland TD-15KV V-Drums).
I realize I'm doing something wrong or just forgot a step. I created a new midi track in a Pro Tools session and set the input and output to the network sessions name and midi channel 10. I get no midi response. I also have the optical digital outputs from the mini going into the optical i/o of my 192 I/O No problems there .
Anyone know how to get this to work??
Thanks in advance!!!!!
Armando
BFD2 Crashes PT 7 - ASIO Driver problem? gganz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-14-2011 08:43 AM
BFD2 in PTLE8 not getting MIDI from MPD26 jurann 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-03-2010 01:32 AM
BFD2 Grooves to PT8 Midi Tracks for Midi Editor? Reesho Virtual Instruments 2 01-06-2010 09:27 AM
Using Pro Tools Midi Editor for BFD2 drum mapping Qrackaduck Virtual Instruments 4 10-15-2009 08:53 AM
BFD2 & PT8 Super Strange Problem marfbeatz Pro Tools TDM Systems (Mac) 4 02-05-2009 03:55 PM
