Old 04-25-2015, 03:48 PM
CKSFX CKSFX is offline
Default PT 12 Save As Template Error
Anyone else getting an error while trying to save a session as a template? Here is the the error message.
Could not save as "SessionName" because Assertion in "/Volumes/Development/148208/ProTools/NewFileLibs/CoreFoundation/MacBuild/../../Sys/Sys_FileLoc.cpp" line 199
Pro Tools 12. 2014 Mac Book Pro. OS 10.10.3: UA Apollo Twin Duo
Old 04-26-2015, 10:33 AM
Default Re: PT 12 Save As Template Error
Figured this out...
I just got a new mac and Apple likes to hide your hard disk which PT can't handle. So
Before Installing Pro Tools
1st - Go to the finder preferences, and select show Hard Disks on the desk top and also for the side bar. if you don't you may end up having a LOT of problems. Including no templates, presets and crashing on load due to a Workspace.wksp problem...
2nd - Install pro tools before anything else so that it gets all of its folders set up. I had installed my UA apollo first, which created a Pro Tools folder in the same place that the installer creates one. I guess when this happens the pro tools installer thinks that it already installed everything in that folder. Which included session templates AND plug in settings. Which i had neither of.
3rd - install your interface and any 3rd party plugs. I'm hoping I don't have any more issues but i'll post if i come across any more problems with 12.
This may be old news to some and if you're not setting up a new system you will probably be fine. It's pretty ridiculous that they haven't fixed this issue for PT 12. It seems it's been a thorn in peoples sides for a while now. Get with it avid.
Old 12-16-2015, 10:56 AM
David Hughes David Hughes is offline
Thanks for posting this info. I was also able to get the Session Templates option to work by just creating a folder named Session Templates in the Pro Tools folder in the documents section of the User area.
User > current user > Documents > Pro Tools > Session Templates
We're running the new "El Capitan" OSX software and encountered the same "line 199" problem.
We're using the new Apollo 8p and it has been running smoothly with PT12.3.1.
David Hughes
Sound Designer
shineonstudio.com
Mac Pro 2 x 2.4GHz Quad Core Intel Xeon, 14GB 1066 MHz DDR3, Avid OMNI HD (Rev A), Digidesign 192, Pro Tools HD v. 10.3.9
Last edited by David Hughes; 12-16-2015 at 11:43 AM. Reason: Updated the workflow path info.
Old 01-26-2016, 05:09 PM
the hecksome the hecksome is offline
Creating the folder in documents>pro tools worked for me.
Thanks!
Old 02-17-2016, 02:58 PM
priorytools priorytools is offline
Very, very good to find this thread.
Thanks for sharing this folks.
One question, Can I just copy my PT 11 plugin settings into a "self made" session plugins folder on the main rig?
IE, I don't have v12 plugin settings any where?
~ Trashcan Mac Pro late 2013 - 64 GB RAM - 10.12.6 / Pro Tools Ultimate 2019.6 / HDX 2 + UAD2 PCIe OCTO in Magma Expressbox 3T / HD I/O's x 4 + 1 x 96io / Avid S6 M10-24-5 V19.12 ~
~ MBP 15" 2.8 Intel Core i7 -10.12.6 /Apollo 16 / Steinberg U22 / Artist MIx / Pro Tools HD 12.8.3 - UAD2 V8 / UAD2 Satellite DUO ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / HEAT / Magma PE6R4 / ProControl 24 faders / UAD2 QUAD PCIe ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Artist MIx ~
Old 04-05-2017, 06:57 AM
Artkon Artkon is offline
Hey everyone, just found this thread since I've been having exact same issues with my newly installed PT 12.7.1.
CKSFX - thanks very much for your troubleshooting. I have exact same setup as you with UA Apollo Twin Duo and it seems like same issue occurred.
I just got a new mac and Apple likes to hide your hard disk which PT can't handle. So Exactly same as me!
Before I reinstall my entire system from scratch, which is a pain, I wonder if there's a work around. Few things that has happened to me and hope you can help:
1. My Documents Folder only has - Pro Tools > Plug-in Settings - which only has UAD plugin presets in it.
2. In PT preferences - Operations - User Media and Setting Location - there seems to be directory paths to (Documentation and Settings ; Project Media Cache ; Sound Libraries), which do not seem to exist anywhere. This is pretty concerning obviously.
3. On PT start up - Templates option is greyed-out, which probably means that this directory doesn't exist also.
So from above issues I wonder what else that hasn't been installed with PT installation? Do you know exactly what my Documents Folder "should look like"?
I did locate my PT plugins in Hard Drive > Library > Application Support > Avid > Plug-Ins
So at this point I am leaning towards reinstalling everything from scratch, with PT12 firstly, then UA Interface etc, as CKSFX mentioned above.
Any suggestions would be awesome!
Cheers
MacBook Pro (Retina, Mid 2012) 10.12.4 Sierra
UA Apollo Twin Duo Core
Pro Tools 12.7.1
Maschine Studio
Komplete 9
Old 04-05-2017, 07:03 AM
furthermore to above I am getting error when trying to same Template Session...
Could not save as "Untitled" because Assertion in "/Volumes/Development/200028/ProTools/NewFileLibs/Sys/Sys_FileLoc.cpp", line 199.
Pro Tools 12.7.1
Maschine Studio
Komplete 9
Old 04-05-2017, 12:31 PM
acmost acmost is offline
Hey yeah, forgot about that 'feature'...thanks for posting!
Old 04-05-2017, 11:06 PM
Hey guys...Update....
Upon moving my UAD plugin settings folder from Documents > Pro Tools to another Universal Audio Folder, magically all my PT folders appeared in before mentioned Pro Tools folder - such as (Project Cache ; Session Templates etc..)
Weird....
Pro Tools 12.7.1
Maschine Studio
Komplete 9
Can't Save Template PT 11.1.3 - OSX 10.9.2 gtodd876 Pro Tools 11 2 12-16-2014 05:07 AM
Unable to save as template doesthisexist Pro Tools 10 1 11-26-2013 08:50 AM
Can't save template on PT 10.3.2 Blackers Pro Tools 10 4 12-22-2012 05:17 PM
Want to save the tracks and mixer as a template? Intuition Pro Tools 9 2 12-01-2011 10:53 PM
Is it possible to save PT as a template? Imagine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-12-2003 04:46 PM
