Old 12-07-2015, 09:15 PM
alk3997 alk3997 is offline
Default Re: Off Line Bounce Time Wrong
Sounds easy enough. Thank you!
Old 12-07-2015, 11:18 PM
hooksound hooksound is offline
1. Make a start marker.
2. Make an end marker safely beyond any tails.
3. Click the start marker in the Memory Locations window.
4. Hold shift and click the end marker in the Memory Locations window.
The timeline between start and end is now selected, and ready for bounce etc.
Pro Tools 10.3.10, Cubase Artist 7.5.40, Allen & Heath Qu-16, Focusrite Scarlett 18i8 2G, Fujitsu Lifebook AH532, Intel Core i7-3612QM, 8 GB RAM, Windows 7 Professional SP1 64 bit
Old 12-08-2015, 07:23 AM
The Weed's Avatar
The Weed The Weed is offline
Or, if the selection you want won't be moved: Make your selection, open a Marker and change it from Absolute to Selection, name it and now, when you recall the Marker Location, the selection will be highlighted.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 09-14-2018, 08:23 PM
12StringJ 12StringJ is offline
In 12.7 on my Windows machines, offline bounce consistently miscalculates the total song length by adding 60 seconds of silence at the end. The moment the bounce starts one can see that the song length is wrong by exactly 60 seconds. Having to "select" the song length every time may be a workaround, but Avid could do better than that. Real time bounce does not have this problem.
Time Stamp Wrong Please Help curtcosmic Avid Pro Mixing General Discussion 2 11-05-2017 12:17 PM
BIG BUG: Wrong playlist calculations when using AS Pitch 'n Time or Avid Time Shift Franco1967 Pro Tools 11 1 01-25-2014 11:31 AM
Is it possible to duplicate time signiatures on the time line Maddawg383 macOS 4 01-13-2012 01:47 PM
Rail, please help ! Mp3 bounce wrong !!! Aquarius Pro Tools TDM Systems (Mac) 5 02-07-2006 04:35 PM
Bounce is in the wrong pitch Notefarm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-24-2005 12:45 PM
