Kick drum eq? Help!
So far my problems have been limited to small unimportant things but im having a dilema when it comes down to making a kick drum sound tight and punchy like on most releases i hear on the radio etc. Im trying to find out how to get that awsome kick sound not a booming thump but a nice clean tight slightly fat kick
can anyone help? [img]images/icons/confused.gif[/img] Quote:
Re: Kick drum eq? Help!
Try a 421 up close to the skin where the kick hits,and an AKG D112 just outside the air hole.
Mix to taste, better if tracked seperately and mixed later. [img]images/icons/grin.gif[/img] |
if you´re refering to anything heavy i believe it´s mostly triggered samples.
cheers jorge |
Try adding some EQ in the 2-4Khz range to capture the snap of the hammer on the drum. If your mixer or plugin can do a frequency scan, try to find the sweet spot in that range. Also, don't over EQ the very low frequencies. A very small amout of reverb might help, but really not that much.
Digi002 Rack Mac Pro 8-core 3Ghz 8gb RAM 3X 500GB 7,200 SATA DRIVES OSX 10.5.7 PTLE 8.0cs3 |
boost 60 - 80 hz, cut round about 250hz and to add a bit of click, boost around 5k.
Using a good "gate" like a drawmer can add a little extra punch. Also a high compression ratio combined with the above can help a kick drum sit well in a mix without being overpowering and losing its dynamics. An SM58 will do mic wise as long as the kick drum itself sounds good and its placement is right. But there are better mics for sound pressure level and frequency response, if you can be arsed reading up about it.
Andy Bowes Imperial Recording Studio Liverpool |
Kick Drum | dBHEAD | Tips & Tricks | 6 | 10-11-2011 12:01 PM |
Help with Kick Drum | torquemada | Tips & Tricks | 13 | 11-05-2006 07:20 AM |
2nd mic on Kick drum? | bigbubbaj | Tips & Tricks | 17 | 08-09-2004 05:10 AM |
60 Hz Kick drum | Brain Digger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 06-14-2004 10:37 AM |
Senheiser MD 421 or Shure Beta 52 for kick drum?r kick drum mic? | H-man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 08-16-2001 07:07 AM |
