How can I format a Windows and Mac Drive?????
I just purchased an external 120GB FW/USB drive for my personal use and I'm wondering what is the best way to format it. I found that as FAT 32 it works on both platforms.....I work on a g4 733 with about a gig of ram and usually work on windows computers.....on the
windows end I just want to use the drive for storage......computer programs, beats, and audio....etc...... on the mac side I want to be able to use it as a PT audio drive and work on music from it..... Can you guys please help me on how I should format this drive....should I leave it as 1 FAT32 partition or should I break it up into smaller partiations with one being for Windows and one being for MAC? and if so which formats should I format each partition as? |
Re: How can I format a Windows and Mac Drive?????
make partitions less than ~30 gigs for FAT32 for the greatest compatibility, and make any size HFS+ partition for use with the mac
Perhaps you should instead of worrying about the partitioning look into a program called MacDrive5 which will allow a macintosh volume to work on a PC as well.
Cavell Studios |
I actually do have Mac Drive 5 but I don't wanna have to carry the program everywhere with me.....I love the program and it works wonders for me.....maybe that would be a better option to just configure it for mac, but what I am trying to do is put a lot of PC data on the drive as well as use it for recording....so I want the drive to be able to perform well in the recording atmosphere...
Yes Chris is right. MacDrive is a Windose app that lets windose read HFS+ mac drives. It seems to work flawlessly. I used it on a full length feature that was cut on an Avid in windose and transfered to my FCP3 station on the mac. This was the only way I could do it without any problems what so ever. It's great! Highly recommended*****
Good luck!
www.hypeschwartz.com Digi001 (RME adi-8 pro) G4 MMD Dual 1g + 1.25g RAM PTLE 6.4 (DVToolkit) Mac. OS 10.3.3 3 Lacie 80g FW Audio Drives |
Just put all the pc data in a folder labeled something like "PC stuff"...or split up the partitions...it's all up to you.
But, macdrive ROCKS...that program is pretty much the most flawless well engineered piece of software to ever hit the shelves. It's solid as can be, and I've never run into a single bug.
Cavell Studios |
Sorry you got in there befor me. If you format your disc with FAT32 you'll have a 2 Gig limit...Not fun at all. And I found it to corrupt files when opening them on a mac.
My 2 cents
Where, it is not 100% false, just 50% unclear. With FAT32, you have an individual file size limitation of around 2 gigs...not a partition limitation. The ability to get around the 32 gig limit of FAT32 partition size limit is really just a workaround that hasn't seemed to cause any problems for anyone...but keeping the partition sizes under 32 gigs has yielded the best results for having both macs and pc's recognize the partition without error...but, these errors are rare and usually fixable.
Cavell Studios |
Now that I'm a Mac user also, I find Macdrive 5 interesting. Question: can a Mac drive mounted on XP with Macdrive be used as a record/playback drive for PTLE on Windows? Or would it just be for transfer?
Quad 2.5 G5, 4.5G RAM |
Wow this is getting deep......I know both platforms are recognizing all 120 Gbs (well actually about 111) but I'm still confused as to what would be my best option....originally I was thinking I could just format half NTFS (or maybe even FAT32) and just us it on Windows...maybe pull sudio files over for mac sometimes......but format the other half Mac OS Extended.....would this be a problem?....
Mac OS Extended Format Ok For Windows? | Obe1 | Windows | 2 | 07-11-2011 06:11 PM |
Mac TDM pt5 (Pro Tools 5) format to Windows LE 6.4 | sologigolos | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 11-16-2005 05:24 PM |
windows/mac drive format | MFR | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 07-22-2005 06:44 PM |
Windows Media format... ? | Kling3 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-22-2004 05:42 PM |
drive format | dragnfli | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-31-2003 02:20 PM |
