Old 06-19-2020, 07:20 AM
Rockman413 Rockman413 is offline
Default if Wavecache.wfm is corrupted, does it matter?
hi
I wonder if wavecache.wfm file is corrupted ,or duplicated wrongly by another person if placing the session folder on a cloud server and multiple people working on that, or deleted, or in anyway changed in a good or bad way, what will it matter?
Is the worst case is it only affect the display waveform which will never affect audio quality or the audio work we bounced afterwards?
Mac Pro 3.0G 8 Cores PT HD use with Ensemble Thunderbolt
Old 06-19-2020, 07:45 AM
Default Re: if Wavecache.wfm is corrupted, does it matter?
Originally Posted by Rockman413 View Post
hi
You can actually delete the file, a new version is just created when the session is loaded up.
Old 06-19-2020, 10:52 AM
Yes , the thing for us is, a few people are editing this file by putting this file on dropbox, so we got all kinds of .wmf file created when everyone load up the session. So I wonder if this cause any problem?
Old 06-19-2020, 11:04 AM
home_studio home_studio is offline
Well, tell them not upload it or don't use it.
No problem with incorrect wfm file, but it might cause pt to be too occupied with unnecessary task.
2020.12 Ultimate / Mac Pro 6,1 / 6 core 3.5GHz / 64Gb / OSX 10.13.6 / MBox 3 Pro / 2 x Artist Mix / PT|Control / Aja T-Tap
Old 06-19-2020, 11:29 AM
You mean running Pro Tools on a shared remote mount drive? It does not matter if that is CIFS, AFP, NFS, Dropbox, Google Drive, or whatever. You cannot do this. There is no access control/file locking implemented in Pro Tools Sessions. This is very likely to corrupt the session. That you have only corrupted Wavecache until now is lucky. You may have damaged more and just not noticed it.
And even if accessed by a single user why would you want to using slow flakey cloud mounted drives? Drag the session down to your computer if needed and work on it locally. ZIPing (or similar) the images before uploading can help people avoid running off them, Or if one person is distributing updates, make them read only. etc. All pretty straightforward to enforce not doing something incredibly dangerous.
Old 06-19-2020, 11:40 AM
Thanks guys, I totally see what you mean about the possibility of corrupt the main session file, thank you for mentioning to me and it seems we are now able to manage this after we made some rules inside our little team. If anything happens to the main session, we deserve it, nobody to blame, our mistakes...
However, back to the OP, if the .wfm is duplicated/corrupted/ got damaged in all kinds of ways, does it matter? will it cause any potential problems as you can think of?
Old 06-19-2020, 12:07 PM
It's needed to display the waveforms. It's automatically rebuilt just delete it and try... now it *might* appear to get corrupted or missing stuff when you it rebuilds because the files it is rebuilding from are corrupted... try it and see. If people have private copies on their computers (not in a dropbox folder). I would hang onto them until you are sure it is OK. And these things can be subtle, say if several people were working on stuff. They might think all their changes are OK, might even exit and other folks think theirs is still OK... but bad things can happen in the background as the changes sync to the cloud storage
Old 06-19-2020, 02:38 PM
What's the use of the .wfm file, what's the relationship between it and the main session?
Old 06-19-2020, 03:30 PM
JFreak JFreak is online now
It is just what it says, a wave cache. Anything you see on the edit window is cached there for faster performance and if you lose it then waveforms will be recalculated and cached again.
Old 06-20-2020, 12:33 AM
Got it, questino solved.
WaveCache.wfm question ZEUSS Pro Tools 2018 3 10-13-2018 12:47 PM
PT 11/12 Stability and WaveCache.wfm ChazC Pro Tools 12 1 08-18-2016 06:57 AM
Wavecache over 7GB!! noiseboyuk Pro Tools 10 5 11-28-2012 06:29 AM
wavecache.wfm??? redchair 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-28-2006 08:04 AM
WaveCache. wfm on PT7 redchair 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-25-2006 12:57 PM
