Air Instruments "Contents Not Found"
I've found a few threads here with this problem and was reluctant to start another, but there seems to be no solutions. Yesterday I did a clean install of 10.3.6 on a ML 12 core. Velvet and Strike "contents not found". Then I did the 2 gig install of the instruments alone. Same thing. Is this just a ML thing that no one can fix?
Re: Air Instruments "Contents Not Found"
Velvet and strike are optional installs and need to be download and installed separately!! see if this helps... velvet... http://secure.digidesign.com/service...&localeCode=en Strike... http://secure.digidesign.com/service...&localeCode=en Chris
I'll try it again, but these are the original installer files. I found another thread that explains how to redirect to the content. http://duc.avid.com/showthread.php?t=338105
I'll give this a try I guess. |
"The files for installation requirement Pace License Support could not be found..." | KingDingbat | Pro Tools 10 | 4 | 02-11-2019 06:12 AM |
Save as > "Could not 14404 because File or folder not found (-43) while opening "..." | Elias Stiza | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-10-2012 07:06 PM |
Mbox Mini Lights up but "hardware not found" | gramtsupak | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 19 | 12-05-2011 09:07 PM |
Mbox mini installation problem - "Hardware Not Found" | tinsoldierman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 12-18-2010 03:06 AM |
Digi CoreAudio says "Not connected (HW not found)" + Kontakt 4.0.5 problem | stevolution | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 05-04-2010 09:48 PM |
