Old 10-01-2006, 08:50 AM
AURORA4DTH AURORA4DTH is offline
Default Tab To Transient Question
Hey guys is there a way to set some kind of threshold for the tab to transient?. Basically if I am tabbing to each kick drum and dont want it to stop on bleed from outside mics snares etc? Thanx
www.nightskystudios.org
Old 10-01-2006, 10:16 AM
Produce_Dept Produce_Dept is offline
Default Re: Tab To Transient Question
No - no adjustable threshold...
Kurt Bullock
PT 7.4 HD2Accel Digi ProControl
G5 Dual 2.7 3.5gig RAM OS10.4.8
www.zeropointrecording.com
Old 10-01-2006, 10:33 PM
Oh well, thanx anyway. maybe they will make this happen later it would be very helpful to me.
Old 10-02-2006, 03:46 AM
reefer reefer is offline
Try beat detective.
Might get better results on long runs!
Old 10-02-2006, 11:54 PM
ottoman001 ottoman001 is offline
Try using strip silence as a work around (Edit Menu/Strip Silence). It contains a sensitivity slider that you could set to ignore the bleed. When processed you'll end up with a bunch of individual kick regions sans the bleed. This might work for your situation.
Good Luck!
Algorithm difference between tab to transient and option + tab to transient? taiga_with_a_pen Tips & Tricks 2 02-13-2010 10:35 AM
Quick Tab to Transient Question jordan23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 03-07-2004 10:21 AM
Quick Tab to Transient Question jordan23 Tips & Tricks 3 03-02-2004 10:03 PM
Quick Tab to Transient Question... jordan23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-29-2004 08:01 AM
tab to transient question kmshroom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-02-2003 11:47 AM
