Old 04-01-2020, 05:14 PM
Fred Cannons Fred Cannons is offline
Default Da Vince Resolve and Avid HDX
I have just started using Da Vinci Resolve 16 and am trying to route the audio out of my HDX card.
So far unsuccessful.
Anyone know how to do this?
Thanks - Fred
Old 04-01-2020, 10:43 PM
smurfyou smurfyou is offline
Default Re: Da Vince Resolve and Avid HDX
Assuming you have the Core Audio driver installed and have used it with other applications?
It should show up in the Audio I/O Preferences. Under Speaker Configuration use “Manual” instead of System Setting. Monitor Set "Main", then HDX should be listed in Devices. Tell it if you want Stereo or other then assign the outs.
Now I haven't tried Resolve with HDX but it works the same with any Core Audio device.
~Will
Old 04-06-2020, 08:03 PM
Henchman Henchman is offline
The routing page in Davinci Resolve is the most ass backwards system I've ever encountered in my life.
www.markhensley.tv
IMDB Credit List
Living the dream.
Old 01-20-2023, 10:07 AM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Resurrecting an old thread because I've been struggling to get this to work. I found that answer HERE!
This is crucial information because as soon as resolve is installed, there is no way to get audio out if you are using Avid / Digidesign hardware and Coreaudio. And fixing this is very difficult, uninstalling resolve doesn´t fix it. You also have to uninstall PostgreSQL 8.4 (that gets installed with resolve) manually using terminal. This is how you do it in OSX 10.8.5.
1) Stop the server and remove the service:
sudo launchctl unload /Library/LaunchDaemons/com.edb.launchd.postgresql-8.4.plist
2) Remove the plist file:
sudo rm -f /Library/LaunchDaemons/com.edb.launchd.postgresql-8.4.plist
3) Remove the Menu Icons:
sudo rm -rf /Applications/PostgreSQL/8.4
4) Remove the Installation Files:
sudo rm -rf /Library/PostgreSQL/8.4
5) Remove the postgres user:
sudo dscl . delete /Users/postgres
6) Remove the ini file:
sudo rm -f /etc/postgres-reg.ini
I copy/pasted the terminal commands and now it works. And, yes, the routing is atrocious! Going to experiment with the ADR functionality.
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 02-22-2023, 06:57 PM
Matt82au Matt82au is offline
interested to see how you get on with latency and recording. Core audio drivers are generally at bit slower over digilink. Keep us posted!
Matt Perrott
Sound Designer and Engineer
Sydney, Australia
HTML code is On
OMG how i do resolve this ! jeam25 Pro Tools 11 19 08-14-2015 07:21 PM
Can anyone help me resolve this error? ullas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-17-2008 08:00 PM
PT7.1 Won't Launch...can't resolve summersleep 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-07-2006 06:09 PM
USD and Mix don't resolve with 4% pull up filmstud Pro Tools TDM Systems (Mac) 4 12-30-2005 10:43 AM
Should be simple to resolve??? Guit4Brains 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-23-2005 09:09 AM
