#31
#32
Re: Pro Tools 10 on Windows 8??
Hi There, and Yes I'm saying that, PT 10. and PT 9 are Installed on Windows 8, So yes, both are Installed and I only Run PT 10 Of course.
Pro Tools 2021.12 UAudio Apollo X8, 8 Duo & Apollo Twin. Mac mini M1 8 on Ram, 256gb, Thunderbolt 3 KRK V88. Yamaha HS7 Korg ESX-1 MBOX2 003Rack Producing My Own Life |
#33
How can you have both installed at the same time!?
#34
You cannot, it's impossible, as we all know, to have two versions of Pro Tools installed at once on the same boot/system image. So at best he has managed to overlay/corrupt files from one install with files from the other.
Trying this is not good advice to give to other users it's going to end up with users having complete messes of installs that will need to be fully removed and replaced. Darryl |
#35
Hi guys, Ok I try to explain, how is this possible, Fist I install PT 10, when I run PT for fist time, DAE error -13001 appear. so I go to PT icon on the desktop, or All Programs, Click with secondary on the PT icon, check Run as Administrator. on compatibility tab. (Resolve DAE error -13001)
The other situation, was cache dialog. So I decide install PT 9... without uninstall PT 10, (If you try to Install older version, its when PT don't let go back). When PT 10.3.0 run ok, I uninstall PT 9, and re-check if PT 10.3.0 run...again. Yes PT run without any problem..
#36
Ok ok .. where can I download protools 9 ?
#37
I'm running 10.3 on an old Toshiba laptop with Win 8 RTM, it appears to work fine with my Line 6 audio device, though I haven't really pushed it. OTOH, with ASIO4ALL, 100% guarantee to freeze system regardless of session and no apparent sequence of events or operations - hard reset of laptop is required. I've always found ASIO4ALL a little flaky anyway, but it does come in handy sometimes.
Edit: An odd issue - the Pod Farm software and drivers work fine except for Line6 Monkey - which shows nothing installed. Probably have a lot of this type of thing going on with the release of Win8 and won't be able to run a full Win8 production system for 6 months or so after the release - time to get everything up to speed. I think I'll quit playing around and revisit this stuff next year.
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
#38
There is a solution , its stupid but it works !!!
First you install Protools 10 after that, you install protools 9 (no need voor key) en than you uninstall protools 9 Done !!! Protools 10 works in windows8 !! |
#39
Thanks for the replies guys! I will install 9 then 10 when I get it and it should work! :)
#40
Darryl |
Pro Tools 11 on Windows 7 or Windows 8? | ianbee | Windows | 6 | 08-15-2013 04:04 PM |
Upgrade From Pro Tools LE (Windows XP) to 10 (Windows 7) | miek07 | Windows | 3 | 07-26-2012 07:49 PM |
Updating Pro Tools and Mbox from Windows XP to Windows 7 | ryanjantz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-29-2011 04:22 PM |
Opening a pro-tools HD session on a windows Pro-Tools LE M-powered system | rhodamorgan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-21-2010 05:31 PM |
Pro Tools LE vs. Pro Tools M-Audio - Any difference? Windows 7 | gbross | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-21-2009 08:24 PM |
