Old 10-22-2011, 06:34 AM
duderonomi duderonomi is offline
Default PT10 Native Instruments compatibility?
Anyone updated to PT10 who has NI instrument plug ins?
Any issues?
The compatibility chart says:
  • With a few exceptions on Mac OS Lion (listed below), AudioSuite, RTAS, and TDM plug-ins compatible with Pro Tools 9 on Snow Leopard are compatible with Pro Tools 10 on both Lion and Snow Leopard.
Known Plug-in Issues — Pro Tools 10 on Mac OS Lion:
  • Waves "Tune" renders AudioSuite offset by the handle length (PTSW-147635)
    • Workaround: user must set handle length to "0" in order to properly align audio
  • Vocalign does not align audio with the guide track in Pro Tools (PTSW-149841)
    • Will not properly process with handles. Fix from SynchroArts is in the works
  • Massey DRT issues
    • Update from Massey pending for full compatibility
Would like to verify that there are no known issues before I upgrade.
Thank you in advance.
recording engineer=audio photographer
Old 10-22-2011, 06:52 AM
sebsongs sebsongs is offline
Default Re: PT10 Native Instruments compatibility?
I'm running Kontakt 4 in PT10 with no issues so far.
Have been loading quite large patches and it's working great!
Old 11-05-2011, 12:07 AM
gives's Avatar
gives gives is offline
Fabulous! What I wanted to hear. Kontakt 5 is more stable the 4 as well. btw.. Have Kompete 8 here..
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS
Old 11-05-2011, 12:35 AM
TOM@METRO's Avatar
Running Kontakt here as well.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 11-05-2011, 02:07 AM
Ant B Ant B is offline
Yeah running maschine and komplete 7 and everything is cool
Old 11-28-2011, 07:55 PM
Eiuro Eiuro is offline
Thumbs down Re: PT10 Native Instruments compatibility?
There seems to be a compatibility issue using the newest version of Kontakt 5.0.1 and PT10. Every time I try to load PT10 with Kontakt 5.0.1 installed it crashes. I removed the kontakt5.0.1.dpm file from the plugins folder and replaced it with the original Kontakt 5.0.0 version and it worked fine.
However Session Strings does not work in Kontakt Version 5.0.0. I get an error that says the patch was created using a newer version of the application please upgrade your application to load patch.
Anyone having this problem?
Old 11-29-2011, 12:07 PM
Bushpig Bushpig is offline
Eiuro,
Hi. I'm successfully running Kontakt V5.0.1 with PT10HD, if that's any help.
Steve Bush
www.music180.com/pros/5887
Old 12-18-2011, 12:32 PM
belolab's Avatar
belolab belolab is offline
having issues with Kontakt 5 and Guitar rig 5 in PT10HD. Both can cause crashes, and not necessarily for a particular reason. Almost always crashes if you try to change a patch whilst the session is playing back. But that was always a bit of an issue.
Having lots of plugin issues on PT10HD actually. Gonna try some updates to NI software, and waiting for Autotune Audiosuite fix, and if that doesnt stabilise things will be moving back to PT9
Old 03-12-2012, 11:45 AM
belolab's Avatar
Default
All NI stuff fine for me on pt10hd, but won't work on my lion version. Weird stuff happens on lion.....ni stuff will work for 10-20 seconds then no sound, or metering on the plugin.
Old 03-12-2012, 11:58 AM
meech meech is offline
Komplete 8 and Maschine are both working without a hitch for me in PT 10. I still prefer to host the CPU heavy stuff in VEP, except for Maschine which doesn't work in VEP. If you're using Maschine in PT, you have to set the buffer size to anything OTHER than 1024, or else timing is off.
Kontakt 4 is also working fine :)
HD Native - Apogee Symphony I/O
Mac Pro 6 core 3.33 Westmere 16 GB of RAM
PTHD 10.2
OSX 10.7.5
Native Instruments - xfer fee for instruments? YYR123 Virtual Instruments 3 10-13-2013 04:47 PM
Using PT10 native without the native card Old School Audio Guy Pro Tools HDX & HD Native Systems (Win) 6 02-14-2013 11:11 AM
Native Instruments / PT 8 Leopard compatibility with midi and instument tracks tunespin Virtual Instruments 7 03-24-2010 10:15 AM
Native Instruments Akoustik & Elektrik Piano Compatibility on Leopard & Snow Leopard DigiTechSupt Virtual Instruments 0 01-07-2010 11:08 AM
Native Instruments midnightrambler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 01-19-2009 08:29 AM
