How to export sessions from 7.0 to flash drive and import on 8.0
I want to export a recording session done in the studio with ProTools M-Audio 7.0 to a flash drive and then import it on my home system which has the 8.0 version. I think I have to use the digi - delivery system since the export would not highlight. Also, I think I'll have to remove the plug-in's since they are all different than version I will edit with.
Is this all possible and how do I go about it? Also, I understand that all session data and related data will also have to accompany the session. I've tried this but no luck so far. |
Re: How to export sessions from 7.0 to flash drive and import on 8.0
Jus save copy in to the flash drive instead of exporting...
When u drag the session, or import it, what ever plugs u don't hav won't open of course so u will be ok; or jus drag the session to the other drive & hold shift when u click the session to be opened...
It's really that easy? Okay, I'll try it soon. This will be great if I can get it to work, I'll be able to record at the studio and edit at home.
Thanks for the help. |
Yeahppp... Jus make sure in Setup>preferences>Processing that u have "automatically Copy files on Import checked on both or all machines...
Otherwise, U will be in trubble or even a 'Mudlake'
That's good to know and you say I can leave the plug-ins? I guess I can remove them, if any after I import then change or add the plug-ins I want. Thanks for keeping me out of that murky water.
Indeed. If the plugin doesn't exist in whichever version of PT you bring a session into... it will just warn you, and then grey it out.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
Using a 32gb flash drive for audio drive | K-Bomb | Storage Subsystems | 6 | 08-28-2012 08:56 PM |
Running MIDI ONLY sessions from USB Flash Drive | AndySolomon | Pro Tools M-Powered (Win) | 1 | 11-23-2010 05:11 AM |
Firewire flash drive | :Rob: | Storage Subsystems | 6 | 06-14-2010 10:55 AM |
Using Flash Drive for Sessions in PT 8.0 | mcr3 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 09-16-2009 11:27 AM |
Usb Flash Drive Choices ? Anyone ? | TommyT | Pro Tools TDM Systems (Mac) | 1 | 05-05-2007 02:11 PM |
