Playback Engine Problems!! SANDRA INCLUDED PLEASE HELP!!!
Ok so I've been having issues with playback since I stated working with PT about a month ago.
I thought the issue was buffer locked at 64 in my 26/26. Got that fixed. Thought it was the bandwidth of my Firewire since I was recording to a 1TB Glyph Drive and I did not have the problem when recording the the Hard Drive so I bought a Seagate 1TB internal drive. Still getting all the cracks, hissis and pops. I've updated to the 8.03v2. I've deleated Prefs. I've optimized Windows The only way this is NOT an issue is when I record to my C: Drive. I can record the the C: Drive have it playing back fine. IF I copy the folder to either my other internal or external drive I can't get playback without hises pops and errors. the 9307 or 9703 whatever the standard "cannot process the files fast enough" is. I bought both the Glyph and the Seagate from Sweetwater and they knew that it was to fix my playback problem in PT so there has to be something else wrong with my system. I've tired from 64 to 4000 buffer sizes and all the possible combinations withing the playback engine. KEEP IN MIND IT PLAYS BACK FINE WHEN RECORDING TO MY REGULAR 150G Hard Drive. I wan't to be recording to either the new 1TB Hard Drive or the 1TB Glyph Drive. __________________ SiSoftware Sandra Computer Manufacturer : Gigabyte Model : P55M-UD2 ID : 00000000-00000000-F06C0000-C9350549 Computer Chassis Manufacturer : Gigabyte Type : Desktop Can be locked : No Mainboard Manufacturer : Gigabyte Multi-Processor (MP) Support : No Multi-Processing (MPS) Version : 1.40 Model : P55M-UD2 Version : x.x BIOS : 11/06/2009-P55-7A89RG0EC-00 Chipset : A89R Computer Memory Controller Location : Mainboard Error Correction Capability : None Number of Memory Slots : 4 Maximum Installable Memory : 32GB Bank0/1 - A0 : DIMM 2GB/2304 @ 1.33GHz Bank2/3 - A1 : Empty Bank4/5 - A2 : DIMM 2GB/2304 @ 1.33GHz Bank6/7 - A3 : Empty Chipset Model : Giga-Byte Clarksfield/Lynnfield DMI OEM Device Name : Intel Clarksfield/Lynnfield DMI Revision : B2 Bus : Intel CSI (Quick Path) Front Side Bus Speed : 2x 2.4GHz (4.79GHz) Maximum FSB Speed : 2x 3.2GHz (6.4GHz) In/Out Width : 20-bit / 20-bit Maximum Bus Bandwidth : 18.7GB/s Maximum Power : 20.00W Chipset 1 Hub Interface Type : Hub-Interface Version : 2.00 Number of Ports : 4 Width : 16-bit Full Duplex : Yes Multiplier : 2x Chipset Model : Giga-Byte Core Desktop (Lynnfield) UnCore OEM Device Name : Intel Core Desktop (Lynnfield) UnCore Revision : A5 Bus : Intel CSI (Quick Path) Version : 1.00 Front Side Bus Speed : 2x 2.4GHz (4.79GHz) Maximum FSB Speed : 2x 2.4GHz (4.79GHz) I/O Queue Depth : 64 request(s) Chipset 2 Hub Interface Type : Intel CSI (Quick Path) Version : 1.00 Multiplier : 18x Speed : 2x 2.4GHz (4.79GHz) Logical/Chipset Memory Banks Bank 0 : 2GB DIMM DDR3 9-9-9-24 4-33-11-6 1T Bank 3 : 2GB DIMM DDR3 9-9-9-24 4-33-11-6 1T Maximum Installable Memory : 32GB Supported Memory Types : DIMM DDR3 Scrubbing Channels : 2 Memory Bus Speed : 2x 665MHz (1.33GHz) Maximum Memory Speed : 2x 2GHz (4GHz) Multiplier : 5x Width : 64-bit Integrated in Processor : Yes Cores per Memory Controller : 4 Unit(s) Power Save Mode : No Fixed Hole Present : No Maximum Memory Bus Bandwidth : 20.78GB/s APIC 1 Version : 2.00 Multiplier : 1/2x Maximum Interrupts : 24 IRQ Handler Engaged : Yes Enhanced Support : Yes Memory Module Manufacturer : G.Skill Model : F3-12800CL9-2GBRL Type : 2GB DIMM DDR3 Technology : 8x(1024Mx8) Speed : PC3-12800U DDR3-1600 Standard Timings : 9-9-9-25 4-34-10-5 Version : 1.00 Timing @ 457MHz : 6-6-6-16 3-23-7-3 Timing @ 533MHz : 7-7-7-19 3-26-8-4 Timing @ 610MHz : 8-8-8-22 4-30-9-5 Timing @ 686MHz : 9-9-9-25 4-34-10-5 Enhanced Performance Profiles : Yes Profile @ 800MHz: Optimal : 9-9-9-24 5-39-12-6 2T 1.5V Memory Module Manufacturer : G.Skill Model : F3-12800CL9-2GBRL Type : 2GB DIMM DDR3 Technology : 8x(1024Mx8) Speed : PC3-12800U DDR3-1600 Standard Timings : 9-9-9-25 4-34-10-5 Version : 1.00 Timing @ 457MHz : 6-6-6-16 3-23-7-3 Timing @ 533MHz : 7-7-7-19 3-26-8-4 Timing @ 610MHz : 8-8-8-22 4-30-9-5 Timing @ 686MHz : 9-9-9-25 4-34-10-5 Enhanced Performance Profiles : Yes Profile @ 800MHz: Optimal : 9-9-9-24 5-39-12-6 2T 1.5V Environment Sensors 1 Model : ITE IT8720F LPC Version : 8.00 Mainboard Specific Support : No Environment Sensors 2 Model : Intel Core CPU [P0, C4, T99] Version : 30.05 Mainboard Specific Support : No Environment Sensors 3 Model : ITE ITE820X SMB Version : 0.52 Mainboard Specific Support : No Temperature Sensor(s) Board Temperature : 34.00°C CPU 1 Temperature : 55.00°C td CPU 2/Aux Temperature : 41.00°C Cooling Device(s) Auto Fan Speed Control : No System Fan 1 : 102rpm CPU 1 Fan : 3814rpm Voltage Sensor(s) CPU 1 DC Line : 1.20V CPU 2/Aux DC Line : 1.58V +3.3V DC Line : 3.34V +5V DC Line : 4.95V +12V DC Line : 5.93V -12V DC Line : -0.92V -5V DC Line : -8.48V Standby DC Line : 3.63V Battery DC Line : 3.28V System Bus(es) on Hub 1 Version : 2.30 System Bus 0 : PCI System Bus 1 : PCIe 2.00 x16 2.5Gbps System Bus 2 : PCIe 2.00 x4 2.5Gbps System Bus 3 : PCIe 2.00 x1 2.5Gbps System Bus 4 : PCIe 2.00 x1 2.5Gbps System Bus 5 : PCI66 System Bus 63 : PCI LPC Hub Controller 1 Model : Giga-Byte P55 LPC Interface Controller OEM Device Name : Intel P55 LPC Interface Controller Revision : A6 ACPI Power Management Enabled : Yes Advanced TCO Mode Support : Yes Advanced TCO Mode Enabled : No High Precision Timer Enabled : Yes Number of Precision Timers : 8 System Timer : 14.32MHz Delayed Transaction Enabled : Yes LPC Legacy Controller 1 Type : ITE IT8720F Version : 0.20 Number of Enabled Devices : 4 Disk Controller Model : Giga-Byte P55/PM55/3400 4 port SATA IDE Controller OEM Device Name : Intel P55/PM55/3400 4 port SATA IDE Controller Interface : ATA Revision : A6 Channels : 4 Disk Controller Model : Giga-Byte P55/PM55/3400 2 port SATA IDE Controller OEM Device Name : Intel P55/PM55/3400 2 port SATA IDE Controller Interface : SATA Revision : A6 Maximum SATA Mode : G2 / SATA300 RAID Support : Yes RAID Enabled : No Channels : 2 Disk Controller Model : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller OEM Device Name : Jmicron JMB36X PCIE-to-SATAII/IDE RAID Controller Revision : A3 RAID Support : Yes RAID Enabled : Yes Channels : 2 Disk Controller Model : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller OEM Device Name : Jmicron JMB36X PCIE-to-SATAII/IDE RAID Controller Interface : ATA Revision : A3 Channels : 4 Audio Device Model : Giga-Byte P55/PM55/3400 High Definition Audio OEM Device Name : Intel P55/PM55/3400 High Definition Audio Revision : A6 Type : HD (High-Definition) Audio Version : 1.00 Number of In / Out / Bi-Directional Streams : 4 / 4 / 0 Number of Serial Data Streams : 1 Audio Device Model : Giga-Byte RV730XT Audio device [Radeon HD 4670] OEM Device Name : ATI (AMD) RV730XT Audio device [Radeon HD 4670] Revision : A1 Type : HD (High-Definition) Audio Version : 1.00 Number of In / Out / Bi-Directional Streams : 0 / 1 / 0 Number of Serial Data Streams : 1 USB Controller 1 Model : Giga-Byte P55/PM55/3400 USB Universal Host Controller OEM Device Name : Intel P55/PM55/3400 USB Universal Host Controller Revision : A6 Version : 1.10 Interface : UHCI Channels : 2 Speed : 48MHz Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) Legacy Emulation Enabled : No USB Controller 2 Model : Giga-Byte P55/PM55/3400 USB Universal Host Controller OEM Device Name : Intel P55/PM55/3400 USB Universal Host Controller Revision : A6 Version : 1.10 Interface : UHCI Channels : 2 Speed : 48MHz Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) Legacy Emulation Enabled : No USB Controller 3 Model : Giga-Byte P55/PM55/3400 USB Universal Host Controller OEM Device Name : Intel P55/PM55/3400 USB Universal Host Controller Revision : A6 Version : 1.10 Interface : UHCI Channels : 2 Speed : 48MHz Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) Legacy Emulation Enabled : No USB Controller 4 Model : Giga-Byte P55/PM55/3400 USB2 Enhanced Host Controller OEM Device Name : Intel P55/PM55/3400 USB2 Enhanced Host Controller Revision : A6 Version : 2.00 Specification : 1.00 Interface : EHCI Channels : 6 Companion Controllers : 3 Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) High (480Mbps) Addressing Support : 64-bit Legacy Emulation Enabled : No USB Controller 5 Model : Giga-Byte P55/PM55/3400 USB Universal Host Controller OEM Device Name : Intel P55/PM55/3400 USB Universal Host Controller Revision : A6 Version : 1.10 Interface : UHCI Channels : 2 Speed : 48MHz Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) Legacy Emulation Enabled : No USB Controller 6 Model : Giga-Byte P55/PM55/3400 USB Universal Host Controller OEM Device Name : Intel P55/PM55/3400 USB Universal Host Controller Revision : A6 Version : 1.10 Interface : UHCI Channels : 2 Speed : 48MHz Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) Legacy Emulation Enabled : No USB Controller 7 Model : Giga-Byte P55/PM55/3400 USB Universal Host Controller OEM Device Name : Intel P55/PM55/3400 USB Universal Host Controller Revision : A6 Version : 1.10 Interface : UHCI Channels : 2 Speed : 48MHz Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) Legacy Emulation Enabled : No USB Controller 8 Model : Giga-Byte P55/PM55/3400 USB Universal Host Controller OEM Device Name : Intel P55/PM55/3400 USB Universal Host Controller Revision : A6 Version : 1.10 Interface : UHCI Channels : 2 Speed : 48MHz Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) Legacy Emulation Enabled : No FireWire/1394 Controller 1 Model : Giga-Byte TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller OEM Device Name : TI TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller Revision : A1 Version : 1.10 Interface : OHCI Enhanced Support : Yes Speed : 400MHz SMBus/i2c Controller 1 Model : Intel 801xx/63xx SMBus Version : 0.05 Specification : 2.00 Advanced TCO Mode Enabled : No Slave Device Enabled : Yes PEC Support : Yes Speed : 100kHz Expansion Slot(s) PCI (1h) : PCI 32-bit +5V +3.3V PME i2c/SMBus Full-Length Available PCI (2h) : PCI 32-bit +5V +3.3V PME i2c/SMBus Full-Length Available Port Connector(s) PRIMARY IDE : ATA SECONDARY IDE : ATA FDD : 8251 FIFO / Floppy Disk COM1 : Serial Port 16450 / 9 Pin Dual Inline / DB-9 pin male COM2 : Serial Port 16450 / 9 Pin Dual Inline / DB-9 pin male LPT1 : Parallel Port ECP/EPP / DB-25 pin female / DB-25 pin female Keyboard : Keyboard / PS/2 PS/2 Mouse - No Detected : Mouse / PS/2 / PS/2 USB : USB / USB USB : USB / USB ________________ SiSoftware Sandra SCSI General Properties Controller : 6 Bus : 0 Target ID : 0 Logical Unit No. : 0 General Capabilities Model : WDC WD1500HLFS-01G6U Manufacturer : Western Digital URL : http://www.wdc.com/en/ Interface : SATA Rotational Speed : 10000rpm Revision : 400. Serial Number : W -DXW3L90803445 Translation Mode Disk Geometry CHS Geometry : 18241 x 255 x 63 Bytes Per Sector : 512bytes Capacity : 139.73GB Partitions Information Partition 1 : MBR Boot IFS-NTFS 139.73GB Logical Drives Logical Drive : C: Cache Information Read Cache : Yes Write Cache : No Prefetch Buffer : No _____________ SiSoftware Sandra SCSI General Properties Controller : 6 Bus : 0 Target ID : 1 Logical Unit No. : 0 General Capabilities Model : ST31000528AS Manufacturer : Seagate URL : http://www.seagate.com Height : 3.5" Interface : SATA Revision : CC83 Serial Number : V62PNGSP Translation Mode Disk Geometry CHS Geometry : 121601 x 255 x 63 Bytes Per Sector : 512bytes Capacity : 931.51GB Partitions Information Partition 1 : MBR NTFS 931.51GB Logical Drives Logical Drive : X: Cache Information Read Cache : Yes Write Cache : Yes Prefetch Buffer : No ____________ SiSoftware Sandra Translation Mode Disk Geometry CHS Geometry : 121601 x 255 x 63 Bytes Per Sector : 512bytes Capacity : 931.51GB Partitions Information Partition 1 : MBR IFS-NTFS 244.14GB Partition 2 : MBR IFS-NTFS 244.14GB Partition 3 : MBR IFS-NTFS 221.44GB Partition 4 : MBR IFS-NTFS 221.78GB _________ SiSoftware Sandra SCSI General Properties Controller : 2 Bus : 0 Target ID : 0 Logical Unit No. : 0 General Capabilities Model : TSSTcorp CDDVDW TS-H663B Revision : UO00 Serial Number : 3452313847365348314235303133303020202020 General Capabilities Channel : Master Type : ATAPI Interface : SATA Removable : Yes Present : No Model : TSSTcorp CDDVDW TS-H663B Revision : UO00 Serial Number : R4816GHSB1053100 ATA/ATAPI Version : 7.528 Translation Mode Disk Geometry CHS Geometry : 23 x 64 x 32 Bytes Per Sector : 2kB Capacity : 92MB Partitions Information Partition 0 : MBR FAT32 94.83MB Logical Drives Logical Drive : D: CD Reader Capabilities CD-ROM : Yes CD-R : Yes CD-RW : Yes Multi-Session : Yes Audio Play : Yes CD Writer Capabilities CD-R : Yes CD-RW : Yes SiSoftware Sandra Processor Manufacturer : Intel Model : Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz Speed : 2.8GHz Peak Processing Performance (PPP) : 44.77GFLOPS Adjusted Peak Performance (APP) : 13.43WG Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Bus : Intel CSI (Quick Path) Package : FC LGA1156 Maximum Speed : 2.8GHz / 1x 133MHz (133MHz) Multiplier : 21x Minimum/Maximum/Turbo Multiplier : 12x - 21x - 24x Generation : G8 Name : LFD (Lynnfield) Core i5/i7 QC 45nm 1.7-3.2GHz+ 0.8-1.375V Revision/Stepping : 0 / 1E / 5 Stepping Mask : B1 Microcode : MU061E0503 Core Voltage Rating : 1.125V Min/Max Core Current : 0.000A - 89.000A Maximum Power : 95.00W Maximum Physical / Virtual Addressing : 36-bit / 48-bit Native Page Size : 4kB Co-Processor (FPU) Speed : 2.8GHz Type : Integrated Revision/Stepping : 0 / 1E / 5 Memory Controller Integrated in Processor : Yes Speed : 2.13GHz Multiplier : 16x Cache Information Integrated Data Cache : 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing Integrated Instruction Cache : 32kB, Synchronous, Write-Back, 4-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L2 Cache Multiplier : 1x L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 4 threads sharing L3 Cache Multiplier : 1/16x Upgradeability Socket/Slot : Socket 1156 Supported Speed(s) : 4GHz Processor Power Management Processor Throttling Support : Yes Throttle Range : 12% - 100% _______________ SiSoftware Sandra Computer Buses Interface Version : 2.30 PCI Bus(es) : 6 PCIe Bus(es) : 4 System Bus 0 Type : PCI Multiplier : 1x System Bus 1 Type : PCIe 2.00 x16 5Gbps Multiplier : 3x Bridge : Intel Clarksfield/Lynnfield PCI Express Root Port 1 Device Connected to Port : Giga-Byte RV710 [Radeon HD 4350] System Bus 2 Type : PCIe 2.00 x4 2.5Gbps Multiplier : 3x Bridge : Intel P55/PM55/3400 PCI Express Root Port 1 System Bus 3 Type : PCIe 2.00 x1 2.5Gbps Multiplier : 3x Bridge : Intel P55/PM55/3400 PCI Express Root Port 5 Device Connected to Port : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller System Bus 4 Type : PCIe 2.00 x1 2.5Gbps Multiplier : 3x Bridge : Intel P55/PM55/3400 PCI Express Root Port 6 Device Connected to Port : Giga-Byte RTL8168D/8111D PCIe Gigabit Ethernet Adapter System Bus 5 Type : PCI66 Multiplier : 1x Bridge : Intel 82801xx (ICH2-8), 63xxESB Hub Interface to PCI Bridge System Bus 63 Type : PCI Multiplier : 1x Device Connected to Port : Giga-Byte Core Desktop (Lynnfield) UnCore SiSoftware Sandra General Information Device Name : Profire 2626 Multi Manufacturer : 239 Version : 10.218 Product ID : 65535 / 239 Specific Wave Information Maximum Standard Sampling Bits : 16-bit Maximum Standard Sampling Rate : 96kHz Channels : 65535
Joshua Hodge www.troytracks.com Pro Tools M-Powered 8.03 (2) Custom PCs w/Gigabyte Mother Board Windows XP Service Pack 3 & Windows 7 i5 Processor w/4GB DDR3 RAM Western Digital 150G HD 10K RPM Sea Gate 1.5TB HD 7200 RPM Sea Gate 1TB HD 7200.12 RPM Glyph 1TB External Drive 7200 RPM M-Audio ProFire 26/26 Focusrite Pro 40 (Linked via Dig I/O) Mackie Onyx 1640i M-Audio Oxygen 61 Roland V-Drums TD9 |
Re: Playback Engine Problems!! SANDRA INCLUDED PLEASE HELP!!!
Some thoughts. Disable the JMicron controller in BIOS if you not using it along with the legacy ports like the serial port and parallel ports, floppy etc. This just makes it easier to troubleshoot and eliminates some potential conflicts What are your drives set to in BIOS? IDE? RAID? AHCI? What OS? I didn't see that listed. The Seagate has write caching turned on and your OS drive does not. I would try disabling write caching on the Seagate. I doubt its the issue but should be checked. Do you need all those partitions? You might copy all of you stuff over to the 1 TB external and reformat that drive as a single partition and see if it makes a difference. Make sure that its a Basic disk and not a Dynamic disk. Last but not least there has been a issue with other P55 chipsets returning DAE 1115 errors which were solved by installing a regular old generic PCI USB card. If you have one lying around you might throw it in to try it. I realize that your having a different issue and your using MPowered with a 2626 but thought I would mention it. Disable the unneeded stuff in BIOS first and check what mode your drives are in. Possibly update your chipset drivers by downloading the latest from Intel. Try disabling write caching. Only change one thing at a time. If your not sure what you doing in BIOS consult the manual and make some notes of what you change.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Thank you for the Quick Reply.
Operating System (which was only in my signature sorry) is Windows XP Professional Service Pack 3. When I got up this morning I checked some of the stuff that you asked about (I'll have to do some studying before I get into the BIOS) I can tell you though that the Drives are set to be RAID/IDE I'm pretty sure... Major finding was that my new internal drive is DYNAMIC so I'm following the steps now in my Microsoft Management Console to change it to Basic Also I have disabled write caching on the drive as you mentioned. When comparing all the options of each Hard Drive I noticed that the "Compress drive to save disk space" is checked on the new Hard Drive and the External but not on my C: Drive. I'm thinking that might help as well. I'll go to Intel and check for the latest Updates There as soon as I get the Hard Drive stuff done. I'm having to move all the stuff I put in there to other folders before I change from Dynamic to Basic so it will be a few minutes! THANK YOU AGAIN AND ALL INPUT IS WELCOME!!!
Pro tools 9 choppy playback sandra report included | daniel101 | Pro Tools 9 | 1 | 06-11-2011 11:58 PM |
Have a couple of issues. Can't stop playback after access violation. Sandra included! | DJ Hellfire | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 01-17-2011 12:50 PM |
Three problems since 8.0.4 - Sandra report included. | David Sabine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 10-22-2010 10:44 AM |
problems since 8.0.4 came to town 8^( sandra included | wizayne | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 08-26-2010 10:07 AM |
Mbox 2 Pro, choppy playback. Windows XP. Sandra included! | DJ Hellfire | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 40 | 02-20-2010 06:04 PM |
