#21
Re: Adding Playlist View to MIDI Tracks
Just my observation, but the smaller number of views in the Sketch forum compared to the thousands of views in the "2023.9" thread indicates that Sketch isn't as important as what many are hoping for when reading about the latest release. Most users are likely viewing the 2023.9 thread to see what's been fixed or what's been broke along with the new features. I imagine that despite those numbers, Sketch will get a continued focus on further development. I'm not saying that Sketch isn't the start of cooler things forthcoming but it does shift the focus from the fixes the larger number of users are awaiting. Personally, I don't foresee ever composing a song like Tom Petty & The Heartbreaker's ~Here Comes My Girl~♫♫ with Sketch.* Working out the chords & vocal melody; unplugged with a guitar or piano (away from the computer) will always be a preferred and more authentic way of crafting a song for me. And having MIDI instrumentation work as expected along with the addition of a MIDI playlists feature would contribute to the creative flow on an equal level as Sketch. Just create a drum loop for each section, jam in loop record/playlist mode, choose the best moments with everything already in place or shuffle sections as desired. All within Pro Tools. * Not saying that some Kid Sensation can't or won't
A rough sea makes a smooth sailor. Pro Tools Studio 2022.7|Windows 10 22H2|Focusrite Scarlett 2i2 (2nd Gen)|Dell Inspiron 3650|Intel i5 6th gen|16GB RAM|Samsung T5 SSD's|Hitachi|Touro HDD Toontrack EZdrummer 3|Steven Slate Drums 5.5 + Blackbird Studio EX|Spectrasonics Trilian|Native Instruments Guitar Rig 6 Waves|SSL Native|Fabfilter|Softube|Soundtoys|Nomad Factory Last edited by take77; 11-26-2023 at 03:01 AM. |
#22
Concerned as well! I would argue that a proper MIDI playlist feature would be far more important for creative flow than the development of sketch, since most Pro Tools users would still likely prefer their traditional MIDI workflow supplemented with proper playlists and loop record to playlists function than something new and different.
Pro Tools Ultimate 2024.3.1 MacBook Pro 16" Apple M2 Pro with 12‑core CPU, 19‑core GPU, 16‑core Neural Engine 32 GB unified memory 1TB SSD storage Ventura 13.6.4 |
#23
+1
#24
We need to be able to draw proper curves in the automation lanes too..
#25
+1
Pro Tools Ultimate 2024.3.1 Dell 7820 - dual Xeon 6132 64 gigs of RAM Windows 11 Pro for workstations HD Native PCIe Lynx Aurora with LT-HD Apogee Mytek |
#26
cqd, what do you mean by that?
Also, Cymian maybe change the title to "MIDI and Instrument" tracks so it's super clear :) ? Just called as I'm really trying to make this happen and again, I'd encourage anyone who really is interested to do the same. It took less than 10 minutes If for whatever reason the implementation has to be different, Pro Tools could create a new MIDI track with correct routing for each loop pass, but I feel like undo states could be an issue since track deleting can't be undone. Also, this method would also only be viable for use with VI loop recording/comping rather than recording the audio of an hardware synthesizer and MIDI data) whether or not you are sending the MIDI data to it externally to trigger it "from the desk," or playing the instrument by touching it and also capturing the MIDI data in Pro Tools.
#27
Kerry Smith http://apothekerry.com Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro |
#28
What do you mean by selectable automation curves? I just tested on MIDI volume, and it seems the first 5 pencil tools work the same way they do on audio volume.
Not familiar with those features in Logic and Cubase so I can't comment, but could you not achieve the same in MIDI event list? Not sure what you mean "by the ability to open the targeted instrument plugin"?
#29
The thing is, the developers of these sample libraries don't all use the same method of switching (and some let you select the method). But a lot of them use key-switches (ie MIDI notes that are outside of the range of the instrument) Like a violin, which has a high register, might have keys C0-C1 assigned to change the articulations. But the cello or double-bass in the same library would be voiced in those lower keys, so their key-switches might be up at C5-C6. But either way, if the switches are on MIDI notes, then if you transpose your song or the part, you end up also transposing any key-switches you made as well, and then they trigger the wrong articulations. With the mapping on a lane, you can transpose the MIDI notes on the track, but because the key-switches are programmed in a lane, they wouldn't be affected by the Transpose command, and would still fire off the right notes to change the articulations in the instruments. Also, because every developer, and instrument has their own way of enabling these switches (some features are CC triggered, some Mod Wheel, some Program Change), it's a pain to remember them all, much less to copy-paste. With Articulation mapping, you can (for example) have a section of several string instruments, and just click (or drag between the tracks) when you want: Sustain, Legato, Sul Ponte, Staccato, Staccatisimo, Spiccato, Pizzicato, Col Legno, etc... and not have to worry about which protocol each instrument is using, because the map/DAW will see "Sustain" on the 1st Violins and know that "Sustain" is in this map, and it triggers the correct key or controller, and then it sees "Sustain" on the Celli track, and it knows that "Sustain" for that instrument means trigger it's respective controller or notes. You do still have to set up each instrument (and as I said, 3rd party devs like Babylon Waves, make a whole business out of making these maps) but once it's done, it smooths your workflow by magnitudes. When I'm in the MIDI editor, and I'm editing a track, sometimes I need to access the VI and either change something inside of it, or check a setting (like, portamento legato happens at velocities under xx). In Pro Tools right now, I have to go back to the main Edit Window (or Mix window, whatever), find the VI in the insert slot, and click it to open (I could, and do, use a shortcut to open Insert A on selected track, but you need to make sure the track is selected in the main Edit/Mix windows). When I was trying out Cubase, there was a button, or trigger or something in their MIDI Editor that you could click (or shortcut) that would open the VI on the track you were editing (or had notes from selected, if multiple VIs). Very handy.
#30
Thanks for the insights Kerry. You're so frickin' massive man! lol
Massively helpful & talented that is. Appreciate the know-how. Just sending you something in return for the effort put into your comments & responses.
A rough sea makes a smooth sailor. Pro Tools Studio 2022.7|Windows 10 22H2|Focusrite Scarlett 2i2 (2nd Gen)|Dell Inspiron 3650|Intel i5 6th gen|16GB RAM|Samsung T5 SSD's|Hitachi|Touro HDD Toontrack EZdrummer 3|Steven Slate Drums 5.5 + Blackbird Studio EX|Spectrasonics Trilian|Native Instruments Guitar Rig 6 Waves|SSL Native|Fabfilter|Softube|Soundtoys|Nomad Factory |
How to stop playlist view from turning all tracks the same color? | ryanstewartguitar | Pro Tools 10 | 0 | 12-11-2012 08:54 PM |
View more than 1 playlist in PT9 for comping tracks | Raoul23 | Pro Tools 9 | 3 | 12-15-2010 08:45 AM |
Resizing tracks in Playlist view | davegibbon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-08-2010 05:26 PM |
PT8 - No Playlist View for MIDI Tracks? | weezerboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-23-2008 07:48 PM |
View All "Playlist" Tracks... | Loudnoize Ent. | Pro Tools TDM Systems (Mac) | 4 | 12-11-2004 12:18 AM |
