Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 05-06-2018, 07:01 AM
its2loud its2loud is offline
Default VCA’s conversation starter
Here’s a topic of conversation. Why are new and old mixers refusing to use VCA’s?
Lately I’ve come across a handful of mixers who either refuse to use VCA’s or simply do not understand them. I don’t get this. For me, VCA’s are a huge time saver and make me a much more efficient mixer. Why wouldn’t all mixers want to use them?
Please enlighten me.
Old 05-06-2018, 05:11 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Default Re: VCA’s conversation starter
Honestly the only VCA trashing I have read is from users who were using other DAWs as their primary. So I'm a little surprised at what you are hearing.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 05-09-2018, 12:18 PM
reichman's Avatar
reichman reichman is offline
Lack of understanding. They're not necessary for basic Pro Tools use, and too many people get comfortable with bad habits and slow workflows.
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 05-09-2018, 05:30 PM
audiograce audiograce is offline
I can think of NO logical reason to avoid VCA's ... They're a Logistical and Functional Godsend. Period.
...tg...
Warner Bros. Studios
imdb Credits
Old 05-09-2018, 06:05 PM
amagras amagras is offline
There's the answer. Either that or they are on PT 10.
amagrasmusic.com
Old 06-21-2018, 03:54 PM
Jeezer Jeezer is offline
VCAs are my primary way of zipping around fast while mixing on the D-Command, it practically begs you to use them for "VCA spill" of an assigned group of tracks to the faders, from that VCA overview in custom fader mode.
That aside it's also great for VCA automation etc that can be coalesced down to tracks, even if you remove a track from a group.
Maybe it's because they have a hardware-world naming scheme which could, not so much put pure ITBers off but maybe make them assume they are irrelevant and related to old mixers which has no business in a 'mouse controlled' DAW on a computer. Had they called them supervisor channels or guardian tracks or remote group control faders... something new maybe people would look into them, VCA is an analog / electronics term related to mixers, amps and synthesizers and could throw some people off (sound more confusing than they are so they never bother with them).
I love VCAs already.
Old 06-27-2018, 12:51 PM
bergj00 bergj00 is offline
Agreed. Could not work without them.
I just wish they would “act” more like VCA’s. Wherein they don’t just control levels. I wish they could adjust parameters on a relative scale over inserts and panners. For example have a master channel strip on the VCA that only passes information through and could change the overall relative values of the channel strips within the VCA controlled group.
Old 08-13-2018, 06:55 AM
Jedisteph's Avatar
Jedisteph Jedisteph is offline
Hello, I use to mix via Vca's with Icon controllers when I started mixing.
Using the rotary knobs to select tracks for target plugin window, spill, it was easy with episodic and small films.
Then tracks got counts got larger, mix delivery are now containing multi-channel tracks, sub tracks etc...
Too many tracks to sift through, so I use Aux's exclusively. The only Vca's are the sound editors if they use them. I rarely adjust editors automation, I redirect to my mixing tracks.
Also Vca's are only Level and I need Eq and panning just as much.
Steph
Old 12-17-2018, 07:47 PM
Bryancole412 Bryancole412 is offline
I'm embarrassed to say that I really don't fully understand the concept of using VCA. Now I'm interested in finding out more. I generally use Aux Bus for Drums, Guitars, Keys and BGVs. Can someone explain the benefits of using VCA? I'm truly interested!
Thanks!
Old 12-18-2018, 06:00 AM
reichman's Avatar
Thanks!
I used to do everything with aux busses. But if you pull a bus down, say -14db, then none of the individual tracks feeding the bus can be raised above that level. In this case a VCA is useful because you can use the VCA to get the 14db of reduction, and then while in spill, grab that individual track that needs to be much higher. And in TV mixes, there might be five groups of tracks all feeding one bus. Much easier to make 5 VCAs instead of adding all those busses.
One last thing: PT faders are post-insert. Riding a bus fader is post-insert. But riding a VCA fader into a bus gives you a rare opportunity to mix pre-insert. Very useful for more advanced dynamics processing.
Nathaniel Reichman
Can anyone remove background noise from recorded voice conversation? devsel General Discussion 3 05-20-2014 04:34 AM
win 7 starter tommikks 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 01-25-2012 09:41 PM
How to EQ a recorded Phone Conversation cksbcville 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-11-2009 02:23 AM
Recording a Telephone Conversation TIMEKEEPER 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 04-10-2005 05:43 AM
Recording a telephone conversation John Link General Discussion 17 01-21-2003 02:52 PM
