Old 12-11-2011, 06:41 PM
Default Re: Interesting...I kinda like PT 10...
Originally Posted by daeron80 View Post
...after duplicating the playlist so you can get back to individual clips if you need them.
Good point David.
Aaron Mulqueen - 001 HD Native
Old 12-11-2011, 11:05 PM
john5193 john5193 is offline
Originally Posted by Chingy View Post
John5193 - what are your computer specs? What sort of RTAS plugs are you running with those sessions? Any help is confirming my system is optimized appropriately would be greatly appreciated.
The Plugs in one of the sessions above:
5 - Peavey ReValver 3.5
2 - Pod Farm 2.5 Platinum
2 - ToonTrack Easy Drummer (nashville for snare & Metalheads for Kicks and Toms)
57 - WAVES SSL G Channels
35 - MCDSP 6030 Ultimate Compressors
15 - Waves Rverb
2 - MCDSP Revolver
3 - WAVES H-Delay
32 - WAVES L1
20 - WAVES IR-1
5 - WAVES C6
2 - WAvES REQ 6
1 - WAVES KRAMER mix tape
1 - WAVES LL316
1 - TRILLIUM LABS CLICK
CPU IS SET TO 1024 SAMPLES FOR MIX DOWN
DELAY COMP SET MAXIMUM
5 CORES 99%
Total CPU usage 68%
TRACKED AND MIXED THROUGH PRESONUS STUDIO LIVE 16.4.2
The workhorse doing all the heavy lifting is a Custom Built (by me):
AMD Phenom II x6 T1100 3.3Ghz Six Core CPU (Not Overclocked)
8GB G-Skill DDR3 1333 Ram (underclocked from 1600)
Asus M4A87TD Motherboard
Saphire ATI Radeon 5770 HD 1GB Graphics Card
2 320 Western Digital 7200RPM HDD (Black caviar)
1 1TB Seagate 7200RPM HDD (baracuda)
Windows 7 home premium 64-bit
VERY VERY STABLE
Wizarding Status REVOKED until I clean out my link box.
Old 12-12-2011, 12:22 AM
Emcha_audio's Avatar
Emcha_audio Emcha_audio is offline
Hey jonh, I noticed you're using the waves ssl g channel. Ever compared it to the new channel strip of pt 10? what's your thought about the two? I've been thinking of getting the ssl 4000 plugin series, but I'm wondering if it's needed now with the channel strip.
Manny.
Wave-T.com
Old 12-12-2011, 08:31 AM
I prefer the SSL hands down. Having worked on the actual console it sounds pretty darn accurate. That being said, the Channel Strip in PT10 is pretty good for not being an emulation of outboard gear.
Old 12-12-2011, 09:00 AM
Chingy Chingy is offline
I guess the key is to make the buffer 1024 when mixing. Logic does it automatically I think, but not a big deal to do it manually.
Does PT have a mode that automatically disables heavy / high-latency plugins when tracking? Logic has it and it disables plugins even on tracks that aren't record enabled (thought not sure if that is necessary). I know PT has the low latency mode for the record enabled tracks and I guess you could just manually deactivate tracks.
Old 12-12-2011, 09:28 AM
kbruff kbruff is offline
Smile Re: Interesting...I kinda like PT 10...
15 - Waves Rverb
2 - MCDSP Revolver
3 - WAVES H-Delay
32 - WAVES L1
20 - WAVES IR-1
5 - WAVES C6
2 - WAvES REQ 6
1 - WAVES LL316
5 CORES 99%
Total CPU usage 68%
VERY VERY STABLE
Impressive
Old 12-12-2011, 12:26 PM
Here is another one for you. Working on it today. No plugs on the vocal chain though. What you are looking at is the instrument (audio) tracks. No VI's on this one. What you don't see is the 30 vocal tracks, 4 Aux busses (all Drums, All Bass, All Guitar, All Vox), the click track, Main Fader, and Print Aux/Audio.
The link is an Image of the session itself instead of me just typing it in. Did it in MSpaint too so no photoshopping happened here.
Its at 5 cores at 99% 1024 samples.
I did it at 256 samples and was only at 46%
http://www.johnsonaudiopro.com/untitled.png
Old 12-12-2011, 12:50 PM
I always leave plugs enabled when tracking....as long as the track latency is not above 1024 i'm fine with a 128-256 buffer.
Old 12-12-2011, 02:51 PM
Nice! I wonder if PT runs better on Windows than a Mac? Did you do any specific optimizations to your machine to get PT to run better?
Old 12-12-2011, 02:54 PM
A few years back I was running some heavy sessions (couple of vi's, 20-40 tracks, lots of plugins on a simple pentium-D (1 core with hyper-threading) I think your machine was having some pretty weird hardware problems, cause it shouldn't have done that one tiny bit. I've never seen a system bugdown with only 5 audio tracks (since they take a lot less cpu usage to run than vi's).
And I'm sure he did the usual windows optimization that is posted on the Avid webstie.
Manny.
Wave-T.com
Gig Success - Kinda Muzza_Boogie Eleven Rack 11 02-21-2012 02:46 PM
Need Help!!! Im kinda new to pro tools LE... rennyren 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 04-07-2007 11:14 PM
It's kinda sad that... Tito Ricci Arballo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-14-2004 01:00 AM
Kinda off topic but... Mr Peete 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-22-2002 12:41 AM
kinda off topic... Mr Peete 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-23-2002 01:40 PM
