Old 08-08-2007, 01:01 AM
ARTHANOR Productions ARTHANOR Productions is offline
Default Resetting D-Command factory firmware
Hi All,
When I had too many fighting faders, I used to be able to reset the D-Command's to its factory firmware and then update it after scanning both units thru ProTools' hardware menu.
To perform this reset, I would press Select, Solo and Mute during the unit's startup, and then I would be able to reset the firmware. It looks like this function has disappeared.
Does anybody know how to do it now? Digi?
Thanks,
David Hadzis
http://www.arthanor.com
Firmware upgrade on 003 Factory with PT9 shobud FireWire and USB Audio Interfaces (Win) 3 05-06-2013 09:32 AM
003 Factory Firmware - How to update? 00011011 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-24-2010 12:43 PM
resetting factory preferences DDP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-17-2005 09:40 PM
Command|8 Firmware 02.01.01 & Firmware Updater 1.4 Avid General Announcements 0 06-08-2004 03:48 PM
Resetting Firmware on PowerMac G4 Dual Optical reduces fan noise naireko 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-17-2002 09:24 AM
