Yosemite way more stable than El Cap and Sierra, best way to downgrade
I tested 12.5.2 and 12.6.1 with OS 10.10.5 / 10.11.6 / and 10.12.1 and without a doubt Yosemite is the most stable, especially when it comes to cpu spikes and errors -9093 and -9173.
Anyone knows if i can install Yosemite on a new Mac Pro purchased today with Sierra preinstalled. If i remember correctly, the bios will prevent you from installing any OS lower than the one that comes with it. |
Re: Yosemite way more stable than El Cap and Sierra, best way to downgrade
I'd be surprised if you couldn't. The "New MacPro" is actually a late 2013 machine which hasn't seen ANY upgrade or revision since, so you should be good.
I've been on the fence about sticking with 10.10.5 when I install
12.6.1 or going with Sierra as there is a lot of luv for that combo. What rig did you base your conclusion on? Thanks!
MacPro 3.46 x 12 (2009) 48g, MacOS 10.12.6, PTHDN 2018.7, 2-Avid 16x16 I/Os, Flashed 7950 Video Card |
The only thing I'd know to try is to install Yosemite on an external drive from an older Mac...then see if the new Mac Pro will boot from it. If it will then clone it over. An issue with that is that the drivers that control fans and heat management may not be compatible with the new Mac Pro.
You can go back as far as 10.9.5, but I'd go to 10.10.5 instead. You'll have to boot from external recovery media/or another system's bootable backup and use disk utility to kill the current data. From there just run the Yosemite installer and install it to the now clean disk in the nMP.
Sierra so far has been way more stable for me with Pro Tools than Yosemite was.
www.HellfireBeats.com UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61 Pro Tools 2021.12 Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2 16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1 27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15 |
I'm getting a lot more -9093 errors with Sierra, even on sessions with very little on. Reminds me of my old G4 when it used to constantly fall over.
Back to 12.4 + Yosemite |
Easiest way I've found is to plug the new mac into an older one and put the new one in Target Disk Mode. From there use disk utility on the older one to format the drive completely. Then I run the OS Yosemite installer which then I can choose which HD to install it on. Choose the new computer connected via target disk mode and you're good to go. Once it finishes it will reboot and you will go through the normal setup process. After that tell it to shut down then disconnect the computers. Reboot the new one and you're all set. |
2012 Mac Pro upgrade to Yosemite -- where to get Yosemite install??? | WildHoney | Pro Tools HDX & HD Native Systems (Mac) | 7 | 07-28-2020 01:45 AM |
HDX and Sierra | Jeffrey Talbot | Pro Tools HDX & HD Native Systems (Mac) | 5 | 11-16-2016 03:21 PM |
OSX Sierra | jack s. | macOS | 25 | 11-05-2016 04:51 AM |
PT 12.6 HDX with OS Sierra. | Quan | Pro Tools 12 | 7 | 11-01-2016 11:49 AM |
Should I Buy Before Sierra? | Cutlerbri | macOS | 21 | 08-09-2016 01:09 PM |
