Re: Cable length in acoustic recording session
Posting double. Damn mobile playing tricks.
Mac Book Pro 2016 Retina, Quad core i7, 2,5 GHz, 16 Gb 1600 MHz RAM, 256 SSD drive, 500 Gb SSD USB3 OSX Sierra 10.12.5, PT 12.7.1, UVI Falcon 1.6 Metric Halo ULN8 3D Interface, NI Komplete Control S49 midikeyboard Macbook Pro M1, 2.5 GHz 8 core CPU, 32 Gb RAM, 1Tb storage, Monterey 12.6.6. PT Ultimate 2023.6, UVI Falcon 3.0 + some soundbanks, Waves Platinum bundle, some free Melda plugz, Metric Halo/Make Believe plugz. Last edited by Voideco; 08-12-2017 at 07:18 AM. |
Thank you very much. I will try this out next week. The recording will be coming friday. I appreciate you taking the time to help me out. There is no band involved but we will record a couple of shamanistic instruments. The AT's record all instruments in the room. The sm57 is there for additional recording of the voice to thicken it somewhat. The m88 tg does the same for the didgeridoo and the shamanic drum so these two mics have to be in line with the AT's. The AT's are allright with eachother. Will try it out next week.
Mac Book Pro 2016 Retina, Quad core i7, 2,5 GHz, 16 Gb 1600 MHz RAM, 256 SSD drive, 500 Gb SSD USB3 OSX Sierra 10.12.5, PT 12.7.1, UVI Falcon 1.6 Metric Halo ULN8 3D Interface, NI Komplete Control S49 midikeyboard Macbook Pro M1, 2.5 GHz 8 core CPU, 32 Gb RAM, 1Tb storage, Monterey 12.6.6. PT Ultimate 2023.6, UVI Falcon 3.0 + some soundbanks, Waves Platinum bundle, some free Melda plugz, Metric Halo/Make Believe plugz. |
Thinking about it some more, in your situation since you are using room mics, perhaps the peaks won't perfectly align, since the sound will hit them at a slightly different point in time. I am not really an expert in phase cancellation, but as long as the peaks are not 180 degrees out of phase with each other, you should be alright. If the peaks were to perfectly align you probably would lose some of the room ambiance.
You can move the tracks back and forth in time relative to each other slightly to get the best sound, or leave them alone and rely on a reverb plugin to fill out the sound.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit. |
Here's a classic article on the three-to-one rule of mic placement. There are many others, too. The principles will definitely have more impact on the results than cable length. http://www.recordingeq.com/articles/321eq.html
Edward |
I can place the AT's some closer to the other mics, that will help.
#16
#17
"Two microphones, intended to pick up two sound sources must be placed apart at least three times the distance that either microphone is from it’s intended sound source." A lot of the time I see people referring to this rule when using 2 mics on the same source - which is just a spaced pair.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (3) Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
#18
Those are technically polarity inverters. Phase/Polarity are not the same thing as phase is an issue of time. Anyway, the great thing about Pro Tools is that you can zoom into the waveform and see exactly what's going on and either time-align tracks or invert the polarity if needed. Of course, use your ears more than anything else!
Tech Tip: Polarity vs. Phase
#19
Excellent!! Now I don't have to invent the wheel again. Thank you all!
So the Audiotechnika's I have setup correctly, that's hereby confirmed (or at least not revoked). The other two mics need to be very close to their intended sound source as the room is very small. Best have their input gain not too high. And, last but not least; they need to be a bit apart from the AT's and eachother. The situation is not very complicated. I made a graphic and tried to upload to make it more visible but Libre Office Draw won't let me save the file as a .jpg. No compatible file format available That's really a drag.
Mac Book Pro 2016 Retina, Quad core i7, 2,5 GHz, 16 Gb 1600 MHz RAM, 256 SSD drive, 500 Gb SSD USB3 OSX Sierra 10.12.5, PT 12.7.1, UVI Falcon 1.6 Metric Halo ULN8 3D Interface, NI Komplete Control S49 midikeyboard Macbook Pro M1, 2.5 GHz 8 core CPU, 32 Gb RAM, 1Tb storage, Monterey 12.6.6. PT Ultimate 2023.6, UVI Falcon 3.0 + some soundbanks, Waves Platinum bundle, some free Melda plugz, Metric Halo/Make Believe plugz. Last edited by Voideco; 08-13-2017 at 03:51 AM. Reason: Avoiding nasty typo's |
#20
Got the picture compatible. Only I wanted to have it shown in this post but no luck.
Note that the blue bar in the left is my recording desk. The 'vertical' walls are about 4,5 meters so the room is almost square. My conclusion is that there is little need to be affraid of phase cancellation, correct me if I'm wrong please. If any phase shifting occurs just drag the tracks minitiously to correct.
Mac Book Pro 2016 Retina, Quad core i7, 2,5 GHz, 16 Gb 1600 MHz RAM, 256 SSD drive, 500 Gb SSD USB3 OSX Sierra 10.12.5, PT 12.7.1, UVI Falcon 1.6 Metric Halo ULN8 3D Interface, NI Komplete Control S49 midikeyboard Macbook Pro M1, 2.5 GHz 8 core CPU, 32 Gb RAM, 1Tb storage, Monterey 12.6.6. PT Ultimate 2023.6, UVI Falcon 3.0 + some soundbanks, Waves Platinum bundle, some free Melda plugz, Metric Halo/Make Believe plugz. Last edited by Voideco; 08-13-2017 at 04:14 AM. |
Cable length | Mitch Griffin | Pro Tools HDX & HD Native Systems (Mac) | 1 | 06-27-2013 05:42 PM |
DVI-D cable length | townsenb | ICON & C|24 | 2 | 01-18-2007 06:04 PM |
Cable Length | GTBannah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-17-2007 10:54 AM |
USB cable length | scottgreiner | Pro Tools TDM Systems (Mac) | 5 | 02-06-2002 06:40 AM |
Cable length on 888/24? | Mount Royal | General Discussion | 2 | 10-04-2000 10:50 AM |
