Amplitube problem
Hi
When i use amplitube and amplitube LE i hear a gorund noise when i use dist.amps I have a PRS Mark Tremonti. Thanks
Mac M1 Studio Ultra - Sonoma Beta OS Avid Carbon Interface Protools Ultimate |
Re: Amplitube problem
Assuming you're using a good cable, into an appropriate preamp, this is a normal side-effect of using a high-gain amp (or amp emulation.)
Quad 2.5 G5, 4.5G RAM |
What is a "gorund" noise? (I'm not trying to be a wise-guy, really!).
Do you mean ground, as in hiss? 3 things: 1) rotate your body & guitar so it is 90-degrees to your computer monitor, that usually helps. Or shut the monitor of during your take. 2) Get a GOOD guitar cable, short & well-shielded, it really does make a difference. 3) Put a noise gate in the signal chain, closer to the the guitar than the recorder (there is greater dynamic range before you add in all the distortion, etc., than after, so the gate works better).
- but the second mouse gets the cheese |
Bazzle |
Help - Problem with PT LE8 & Amplitube | ChazKellie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-01-2010 08:10 PM |
amplitube problem | mbuono | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-26-2005 03:06 PM |
Amplitube problem plz help | mantra | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-17-2004 12:12 PM |
amplitube problem | mbuono | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-07-2004 09:05 PM |
Amplitube Problem | lexluth | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-01-2003 12:27 AM |
