Mach 5 and PT
The Mach 5 plugin window will not stay open when I click out of PT (PT stays open but the plugin window disappears). The window needs to stay open so samples can "drag-n-drop" from the finder into the area of Mach 5's window where it states "drag-n-drop files here." Any comments?
Thanks for help. -c |
Re: Mach 5 and PT
it is tricky but you need to rearrange your windows so you can see the window you are dragging files from, then click and hold down mouse as you drag and the window will not disappear. At least that is the way it worked for me
Re: Mach 5 and PT
Mark's right it is tricky but if you arrange the windows carefully (ie close the mix window) and make the arrange page smaller to fit behind Mach5 you can then open another window (with the samples in) next to the Mach 5
Mach 5 and PT|HD3 | marty lester | Pro Tools TDM Systems (Mac) | 17 | 11-29-2008 12:14 PM |
Mach 5 in PT 7 | roberts | Pro Tools TDM Systems (Mac) | 4 | 11-20-2005 11:24 AM |
Mach Five | Ignatius Reilly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 08-19-2003 05:08 AM |
Mach Five?? | mange72 | Pro Tools TDM Systems (Mac) | 37 | 08-05-2003 12:59 AM |
MACH FIVE | Son of David | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-02-2003 12:47 AM |
