Old 11-20-2010, 06:24 AM
VIStudios VIStudios is offline
Default C|24 firmware update issue and misc. routing ?'s
just finished setting up a brand new HD2 system and i just finished installing PT9 and i'm having the hardest time updating the firmware. it keeps saying that it's unsuccessful and to check the connections. everything is brand new including the computer, so it's not my cables or ports. i can't really figure out what to do.. another thing is i have two HD I/O's and my second one which is slaved to the first has a click every few seconds....
and last but not least, i'm having a HUGE problem getting my main monitors hooked up.. all my CUE headphones are working fine, even my ALT monitors, but I can't get the mains to get a signal. i'm following everything in the C|24 manual and i can't find the right combo.... and to top things off, i have a band coming in to record in an hour. so if anyone could help out with in that time frame i'd forever be in your debt. thanks a bunch!
Old 11-20-2010, 06:39 AM
Meads Meads is offline
Default Re: C|24 firmware update issue and misc. routing ?'s
Don't wanna be a smartass, but it's highly recommended not to change your system significantly, while you're in the middle of a job or planing to start one in an hour.
I don't have a C24, so I can't give you any advise, sorry. Hope you get it fixed in time - and next time just don't.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 11-20-2010, 06:47 AM
this isn't an "official" session. this is my practice band.. and i honestly didn't think all of THIS could go wrong.. everything was working the way i hoped it would for like the 20 minutes i had PT8.
Old 11-20-2010, 06:51 AM
Some suggestions; Disconnect the C24 and just work on getting audio to pass in both directions. Once that works, add the C24 back as a controller(leave off the audio connections for the moment). Once it works as a controller, then dig into the IO to and from the interfaces. Keep in mind that the C24 uses 1 and 3 for left&right(2=center of a surround system).
Old 11-21-2010, 01:39 AM
alright so i ended up getting it to work. but for some reason the second HD I/O that i have connected as an expansion to my first one creates a popping sound every 12 seconds. any idea what it could be?
Old 11-21-2010, 06:47 AM
Sounds like a clocking issue. Maybe add a wordclock cable between the units?
Old 11-21-2010, 11:52 AM
yea that's what i was thinking too, but i tried the word clock signal chain that's in the manual along with two other combos that i though might work and i still get the clicking... could it maybe be fixed through the settings in pro tools?
Old 11-21-2010, 12:56 PM
What happens if you disconnect the second IO? Just wondering where the clicks are coming from
[IMG] code is Off
MBox Pro 3 constant firmware update issue (w/ a twist...) leftalive macOS 3 04-10-2013 01:56 PM
PT8 SYNC HD firmware update issue JThelin Pro Tools TDM Systems (Mac) 4 07-03-2009 09:05 AM
Digi002 Firmware update issue _ron 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-03-2005 03:51 PM
Play button issue after firmware/6.4 update BELA D MEDIA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-26-2004 01:41 PM
