Hello. I did a search, but couldn't find my answer...
I have recently done a couple PT8 upgrades around the studio to the various Mac/ProTools systems we have here. All HD TDM, PCIe.... I've had no problems with any of the other systems. With the PT8 update, I've needed to (like most others) update my firmware for the Sync HD. I have checked all cables, power cycled the sync HD with the "set" button, etc etc. When I launched Pro Tools 8 initially it warned my of the update, so I know it has *some* form of communication established. but all times I've tried to do the update via DigiUtility ... exactly how it states, it always tells me: "Firmware update aborted: couldn't establish communications with the SYNC. Please power cycle it while holding down the "Set" key" system: OSX 10.5.7 4 x 2.25 GHz PowerPC G5 4GB Ram ProTools 8cs3 any ideas????? thanks in advance.... |
I've also seen situations where the HD core card didn't show up as being in the first available slot when you use DigiTest. I once spent 20 minutes trying to update the firmware - then noticed the popup selector in DigiTest that lets you tell it which one is the Core card (and of course, that's what Sync I/O is attached to). Set it, and it was fine.
Not sure if that's your problem, but I figured, what the heck... -Danny (the comments above do not represent the opinion of Avid as I haven't worked there since '08!) |
Is this the same serial cable that was working before? If it is a new one, then do a search for serial+cable and you will find some answers. All serial cables are not created equal. There was a post in the last couple of weeks addressing this. SB
thanks guys.
well. still having the problem. It's the same serial cable that was used previously. I've also tried other cables from machines where the firmware update worked properly. I have selected the proper drop down choice as the "Core." Also tried other ones as well for the hell of it. to no avail. still nadda..... |
Rewire + Sync HD Firmware Update with 8 | JJC | Pro Tools TDM Systems (Mac) | 0 | 02-10-2009 03:23 PM |
SYNC IO Firmware Update Question | nhaudio | Pro Tools TDM Systems (Mac) | 1 | 04-11-2007 11:09 AM |
7.3 cs1? and Sync I/o firmware update | smlworld | Pro Tools TDM Systems (Mac) | 5 | 12-30-2006 07:03 PM |
SYNC IO firmware update weirdness | emf1138 | Pro Tools TDM Systems (Mac) | 3 | 04-29-2004 09:54 PM |
Unable to update Sync I/O firmware | Samhein | Pro Tools TDM Systems (Mac) | 1 | 05-07-2002 09:18 AM |
