Old 01-24-2011, 07:21 PM
JNS JNS is offline
Default Loop-record problem
Hi. I don't usually use Loop-Record, but thought I would try it. Everything seemed to go well and new regions were created as shown in the Regions List. Then I thought I would try the Preference to automatically create new playlists when loop-recording. This is when the trouble started. Everytime I stop the loop-recording process I get the spinning beachball and then PT quits. A couple of times I got a DAE error -1115, but not everytime. I performed DigiTest and all cards passed.
Up until this time I've had no problems with this system for a year even using UAD plugs on as many as 20 tracks and BFD2.
I was wondering if this is a known problem. I did a search, but didn't find anything.
My system is as follows: MacPro 2.8GHz. 8-core, OS 10.5.8, PT 8.0.3cs2, Magma ExpressBox 4, 2 expanded 192s, Sync I/O, HD3 Accel in the chassis, UAD 2-Solo and UAD 2-Duo in the computer.
Any help with this problem would be appreciated.
Thanks,
Jeff
HD3 Accel with 2-192s(expanded) and Rosetta 800, PT 8.0.3cs2/10.5.8 on 8-core 2.8 GHz. MacPro with UAD-2 Solo/Duo and Magma Expressbox4 chassis, Sync I/O, Midi I/O, Control 24;
PTLE 8.0cs3 on Dual-core 2.3GHz. G5(PCIe), 003R
Old 01-25-2011, 07:05 AM
JNS JNS is offline
Default Re: Loop-record problem
Bump
Old 01-25-2011, 07:51 AM
formfunction formfunction is offline
Thanks,
Jeff
This session, all sessions?
Clean prefs/databases?
1115 errors are often associated with expansion chassis'
or drive issues.
good luck, but at least see if it is session specific..
Old 01-25-2011, 08:01 AM
JNS JNS is offline
Thanks for the reply. I've tried it on 3 sessions and same result on all three. I guess I could try a brand new session, also. I haven't trashed Prefs., etc. yet since I wanted to make sure it wasn't some known issue with PT before I went to the trouble.
Jeff
Error: "Pro Tools cannot be put online while in loop play or loop record mode." msg6794 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 11-12-2016 06:09 AM
Loop Record and Loop Playback will not engage? Angelo of Onello 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-28-2008 06:03 PM
Tick timebase - Problem separating regions after Loop Record TimmyP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-26-2008 05:14 PM
Loop record webstereo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 05-04-2007 11:48 AM
