midi shortcut keys not working
Hi-
According to the article http://www.avidblogs.com/pro-tools-2018-1-midi/ I should be able to select midi notes in the midi editor now and move them up and down with the up/down arrow, and by octave with Shift + up/down arrows, but this does not work for me. I can sometimes move it up an octave, but then not down, and sometimes the up arrow will move it down almost an octave but not quite. Please help! I'm on mac os 10.12.6, pro tools 2018. |
Re: midi shortcut keys not working
Some people are finding that they have to click somewhere in the MIDI edit window in order for the new keyboard shortcuts to work. Could that be it?
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
I have the same problem - couldn't find something on the web... ?! It would be great to have a solution...
From what I can tell, the shortcuts seem to be affected by the settings in the events operation window.
For example....if you have transpose set to "up an octave" set in events operation window. But then try to transpose down an octave using a keyboard shortcut. Nothing happens. Or... if you had the events operation window set to "- two half steps", and then tried to transpose down an octave using a keyboard shortcut. It would transpose downward 14 half steps. (adding the setting of the events operation window) Frustrating that it doesn't operate as intended in spite of those settings. |
I'm also having this issue! None of the midi keyboard commands/shortcuts that are described are working. Not up/down arrow to move audio up or down, not tab/opt tab to move a note left or right, etc. etc. Not in edit window or midi editor. Any thoughts?
Ok, I could be wrong but I would guess that what some of us might be doing is consulting out of date resources online. I checked the 12.8.2 manual (duh) and the instructions on how to move individual notes work perfectly.
Pressed some keys now shortcut keys wont work (T,R to zoom etc) | Falcon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 06-11-2016 10:49 AM |
Can't turn off Mac Function keys/turn on PTLE Shortcut keys | b mcgibney | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 09-25-2009 09:15 PM |
shortcut keys and midi | ccastillo123 | MIDI | 0 | 03-25-2006 11:03 PM |
6.x Shortcut Keys | proxy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-21-2003 08:46 AM |
